544,218 active members*
2,919 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Angled surfaceSolidworks CAM professional vs CAMWorks for 3 axis milling (TRAK)
Results 1 to 1 of 1
    Trying to learn CAM/Milling and was wondering if it's works the extra cost to get standard CAMWorks vs Solidworks CAM professional. Didn't seem to have much of a difference and only need 3 axis milling, was told the Volumill was important but it already comes with Professional version. It's about $7K for the standard CAMWorks license, can't imagine spending that much on it but it is worth it? Only plan on doing 3 axis milling on a TRAK machine working on Aluminum.
    Comparison: https://www.javelin-tech.com/blog/20...m-vs-camworks/
    Also, what is the best way to get a smooth tapered/angled surface with Solidworks CAM (see pic)? Probably the easiest way is to place it at an angle and face it as a flat surface, but the surface needs to be a tight tolerance +/-.0005" and I rather not have to take the part out and re-clamp it. I assume using a large ball end mill and small increments to get a smooth surface. I can't seem to get 3 axis working in Solidworks CAM, seems to be alway 2.5D, any tips or info would be appreciated for this noob.
    Thanks!
  1. Replies: 0
    Last Post: 02-18-2021, 03:21 AM
  2. Replies: 3
    Last Post: 12-03-2019, 06:30 PM
  3. Replies: 23
    Last Post: 07-03-2015, 09:29 PM
  4. Best CAM package for introductory professional CAM
    By dent424 in forum Uncategorised CAM Discussion
    Last Post: 09-18-2013, 05:38 PM
