557,886 active members*
4,085 visitors online*
Page 1 of 2 12
Results 1 to 20 of 38
    Feb 2011
    22
    Anilam 3 axis Mill Y axis Lag over Max
    Hi All
    I have acquired a old Mill with a Anilam 3000M conversion in it with Indramat 3TRM 2 servo control. I have reconnected all the computer all that seams to work. The problem is when I reset the servo motors all 3 of them turn a little then they trip out and get an error message is Y axis over Lag Max, this seams to be a random thing as to whether it is X , Y or Z axis. I get it every time. The previous people said the hard drive and the back up hard drive should still have all the settings on them from when they used it as a CNC mill. The position of the table is correct in the DRO and is reading correctly when manually moved. I have removed the drive belts from the servos but this made no difference checked all fuses etc that I can find. I have all the Anilam manuals but not the indramat manual but don't understand much of it. What should I be looking at checking? And in the settings should it have an Home position, software limits and vector limits programed.
    I know it is an old machine and i have been told to throw it away and just buy one that works but its not a production machine and I bought what I could afford. I just need to sort it out now.
    Many thanks for the help in advance.
    Mark
    Aug 2009
    1281
    Re: Anilam 3 axis Mill Y axis Lag over Max
    Quote Originally Posted by markems0 View Post
    ...the belts may have to on for Encoder feedback to work, depending on where and what they are on each axis of your machine.
    Attached Files Attached Files
    Feb 2011
    22
    Hi
    Encoders are on the end of the motors so still working with belts off. Will look at the manual.
    Dec 2013
    5603
    Hi All
    Mark
    How much reconnection did you have to do? It could be that the encoders and/or tachs and motors are running in opposite directions, that would cause a nearly instant lag error. The randomness may just be from which drive faults first and shuts everything down as it should.
    Here is a link to the Indramat manual https://www.docdroid.net/qwMiB7x/3trm2-manual-pdf
    I wouldn't throw the machine away, but a controls upgrade might be worth looking at. The motors and drives could be used with new controls.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2011
    22
    Hi
    I only had to reconnect the computer, all the servo drives and motors were connected. The DSP board is in the computer box though. Looking at the manual do I need a test board to check and balance set the motors?
    Dec 2013
    5603
    To get the motors to run properly under computer control there four things that must be properly connected. 1) the armature wires (motor power), 2) the tach feedback to the drive, 3) the encoder connection to the computer, and 4) the +/- 10V analog command signal to the drive. They all have to be in agreement as to direction. Since the motor connections to the drives were undisturbed, then most likely the armature and tach feedback are correctly connected. So that leaves the encoder and analog connections to the computer.
    You noted that when moving the axes manually the DRO seems correct.
    Just as a quick encoder check when standing in front of the machine:
    X axis, table moving to the left, X DRO should be counting in the positive direction
    Y axis, table moving away from you, Y DRO should be counting in the negative direction.
    Z axis, quill moving down, Z DRO should be counting in the negative direction.
    If encoders are all correct, then are the analog signals from the computer connected to the correct drive? And with the correct polarity?
    I don't think you need a test board at this point.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2011
    22
    Hi
    Thanks for the information. I have checked the directions for XY and Z they are as you said. I have a small video of what it is doing if it helps. Where would you check the taco and 10v signal
    Thanks. Mark
    Dec 2013
    5603
    From the Indramat manual, it looks like the +/- 10V analog signal is connected to E101 and E102 and the tach is connected to E103 and 0V
    The exact polarity of the connections may be in the Analim manual.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2011
    22
    Hi
    I checked the voltage today. The Taco is connected to E101 and 0V I got a reading of 2.74 V dc for E101 2.74 V dc for E201 and 2.76 V dc for E301. Between E103 and 0V i get 00.0 V on all 3 axis. Should i be getting 10V there?
    Feb 2011
    22
    Hi
    Sorry it is the Taco that is on E103 etc not +/-10V
    So E101 and 0 Vdc I get 2.74v E201 is 2.74v and E301 is 2.76v dc should these be 10v ? These go back to the computer and it is .01 v more on all axis cumming out of the computer.
    Taco E103 is 00.0v that is the same for all 3 axis. I do get a reading on this when i manually move the axis but not a steady reading it jumps allover I presume it is a pulse not a steady volt reading I will have to dig out my oscilloscope and see if it still works it is only a small hand held one but may do the job.
    Mark
    Feb 2011
    22
    Also today noticed that on the back of the board that to computer and DSC plugs into are 4 LED's only 3 are lit up D3 is out.
    Dec 2013
    5603
    According to the drawings the taco should be connected to E103 and 0V, the Analog command signal should be connected to E101 and E102 or possibly E101 and 0V.
    With the motor not turning there should be 0V across the taco inputs. And if wired correctly I would expect near 0V on the analog lines. As you rotate the motor the taco should start generating a voltage proportional to the speed of rotation, normally about 7V per 1000 RPM.
    In both cases above, the polarity must be correct for the system to work.
    I have no idea what the LEDs mean.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2011
    22
    Hi
    I have been reading the manual and the LED's on the back board are to show the 12v and 5v + & - are working. the 3rd LED represents the 5v- which is not used so should not be lit. So they are correct. Just reading the indramat manual to see how I make the Volts across E101 and 0V to be 0V and not the 2.74 that I have.
    Mark
    Dec 2013
    5603
    Hi
    Mark
    That voltage should come from the controller, not from the drive. That is the command signal from the controller, tells the drive how fast to spin the motor. 0V (or E101 connected to 0V) should mean the motor is stopped and holding position. A positive voltage on E101 should run the motor forward, a negative (relative to the 0V terminal) voltage on E101 should run the motor in the other direction.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2009
    1281
    ...double checking wiring/cables for Axis feedback may need a second look, just to be sure.
    If, you can test each Axis in Jog mode before reset....try using .0001" and step each Axis to see if or when they Lag error out. May help narrow down which Axis
    Feb 2011
    22
    Quote Originally Posted by machinehop5 View Post
    Hi I will have another look at the wiring. I cannot check the drives in jog mode because as soon as I reset the servos all 3 of them set off run for 2 seconds then trip. With x,Y or z lag over max. I only have 13.8 v on the test pins on the DSP board. Am I right in saying the small axis adjuster pots are to bring the volts down to 0v. Dose the axis feedback come from the taco or the encoder.
  17. #17
    Aug 2009
    1281
    Tach velocity feedback goes to the Intramat Servo Amp and the Encoder position feedback goes to the Anilam controller.
  18. #18
    Aug 2009
    1281
    Looking in the Anilam pdf on Pages 9-10...I would say yes. But, you have an Intramat Servo Amp so, this may not apply.
    snip
    1.
    Press Balance (F6) to output a zero voltage signal to the axis.
    2.
    Press START.
    3.
    Refer to Figure 5. Make adjustments for axis outputs 0–3 on the DSP2 Board at potentiometers R108-R111 respectively.
    4.
    Adjust the potentiometer for the selected axis until the voltage across the pins is 0 VDC (± 0.001V).
    5.
    Press MANUAL (F4) to cancel the test.
    endsnip
    ...There are Pots on the Intramat Amp's pdf for zero drift I see. Chapter 3.3.2 ZERO SPEED-ADJUSTMENT
  19. #19
    Aug 2009
    1281
    Quote Originally Posted by Jim Dawson View Post
    ...thank Jim for the manual Right to Repair
  20. #20
    Feb 2011
    22
    Hi
    Thanks for the info I tried that balance procedure on the x axis but can only get it down to 2.52 volts at E101. What else can i do? I am now lost.
Page 1 of 2 12
  1. Anilam Crusader M 3 Axis Mill will not boot up.
    By Sierevello in forum General CNC Machine Related Electronics
    Last Post: 10-23-2018, 04:31 PM
  2. Anilam 5000M x lag over max help
    By bradmac169 in forum Australia, New Zealand Club House
    Last Post: 09-12-2017, 04:18 AM
  3. Anilam 1400 3 axis bed mill
    By Jmek in forum General CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-03-2014, 07:45 PM
  4. SERVO LAG EXCESS Y AXIS (Y axis won't home)
    By eltorio in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-19-2011, 01:10 PM
  5. Anilam Error "X Lag over max"
    By BenSteigerwald in forum Controller & Computer Solutions
    Last Post: 05-02-2009, 03:37 AM
