548,477 active members*
2,278 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Anyone tried these cheap eBay 5-axis trunnions with harmonic drives?
Results 1 to 11 of 11
    Mar 2010
    66
    https://www.ebay.ca/itm/223958526107...53.m1438.l2649
    I'm tempted to take a chance on one. I'm making some very small parts which need to be cut on 4 sides plus an angled slot so indexed 5-axis cutting would save a ton of re-clamping on my 3-axis bench top mill.
    If anyone has tried this one or anything similar I would love to hear about your experience.
    Thanks,
    Leo
    Re: Anyone tried these cheap eBay 5-axis trunnions with harmonic drives?
    Curious about the accuracy and quality, please kindly share experience after you got one.
    Mar 2015
    25
    Greetings,
    I wrote to the seller asking for a PDF of the Owner's Manual.
    Reply was...
    Hi
    Thanks for your message .
    Sorry , the item do not come with user manual .
    We do appreciate your understanding and time.
    If you have any questions,feel free to contact us,we are always here to serve you.
    Best regards"
    While it seems a useful tool, I would look further and find a seller/vendor that will offer help should it be needed.
    Cheers,
    Dave
    It's listed for engraving, which to me would seem to imply thats it's probably not well suited to actual 5 axis machining. Even with 100:1 reduction, the steppers don't look particularly large.
    Dec 2005
    433
    If it on eBay then it is probably on Aliexpress. You might find other sellers there willing to give more information.
    The thickness of the side wall where the connector is located tells me the maximum proportion of the bearing in that wall.
    Also the construction material is aluminum, including the chuck.
    So overall if I was machining steel, I wouldn't use a cutter bigger than about .048" diameter.
    Also take careful note of the height of the unit, add your material holding to that height. That leaves little Z movement left to work with.
    And the Z height of the head will be far up to column, increasing vibration.
    Careful what you wish for.
    Mar 2010
    66
    Well I've taken a chance and ordered one.
    I'm only planning to make very small parts out of brass so if it's a genuine harmonic drive mechanism on each axis I think it will meet my needs.
    I'll post again once I've got it set up.
    I look forward to the results.
    Feb 2005
    737
    In the picture it does not look as though the table rotates.
    Halfnutz
    Feb 2008
    462
    Quote Originally Posted by Halfnutz View Post
    Have to look at all the pictures . . . . . https://i.ebayimg.com/images/g/BnEAA...xe/s-l1600.jpg
    Dec 2005
    433
    How will you do the post processing?
    You will have to take great, very extreme care in setting it up. The alignment of ALL the axis of the trunnion to the rest of the machine will have to be accurate, otherwise errors in machining will be a multiple in the error in alignment of the trunnion.
    Feb 2005
    737
    It is hard to tell from the pictures how rigid it is. If you bought one off of ebay from a well established seller with a 30 day no questions asked return policy, you could check it out anyway.. Like cncuser said, the post processing and set up would be critical. It could be a lot of fun using. Let us know how it turns out
    Halfnutz
  1. Chinese Ebay 4th axis Harmonic Drive
    By rey8801 in forum Linear and Rotary Motion
    Last Post: 11-26-2021, 10:19 PM
  2. Replies: 17
    Last Post: 08-22-2021, 11:20 AM
  3. Limitations of cheap 4th axis components off eBay?
    By Goemon in forum DIY CNC Router Table Machines
    Last Post: 09-17-2019, 07:03 AM
  4. Help needed to incorporate harmonic drives in a 4th and 5th axis head.
    By SpookyDad in forum Drilling- and Milling Machines
    Last Post: 07-03-2016, 02:05 PM
