528,358 active members*
2,981 visitors online*
Results 1 to 8 of 8
    Aug 2020
    6
    Appropriating an action to new buttons added to screen set
    I want to move X,Y&Z axis individually by 0.5mm incrementally using new buttons on the screen,I would like to know how to action this,
    The movement would be in both directions (+&-),
    thanks in anticipation
    Gold Member
    Apr 2004
    5115
    Re: Appropriating an action to new buttons added to screen set
    What kind of CNC control software are you asking this about? They all work somewhat differently.
    Andrew Werby
    Website
    Mar 2003
    35100
    In Mach3, using a screen designer, add a button that calls an M Code, like M555
    Create a macro called M555.m1s, with this code:
    Code:
    DIM XMove
    XMove = 0.5
    CurrentAbsInc = GetOemLED(48) ' Get the current G90/G91 state
    Code "G91"
    Code  "G0 X" & XMove
    While IsMoving()
    Wend
    If CurrentAbsInc = 1 Then
    Code "G90"
    End If
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Aug 2020
    6
    Quote Originally Posted by awerby View Post
    Am using Mach3
    Aug 2020
    6
    Code:
    DIM XMove
    XMove = 0.5
    Code "G91"
    Code  "G0 X" & XMove
    While IsMoving()
    Wend
    Code "G90"
    End If
    Thanks for your reply,
    If I have got this right ?,
    I could set up six buttons,
    Two by each axis thus enabling + or- movement in that axis ?,
    Thanks in anticipation.
    Mar 2003
    35100
    Yes, 6 buttons, and 6 macros.
    Gerry
    Aug 2020
    6
    hi,
    thanks for the info,
    do you know if its poss to incorporate a counter either on the button or adjacent to it to register how many increments have been used,
    v new to this, so green as grass!!!,
    all help/advice much appreciated,
    thanks
    Mar 2003
    35100
    Yes. You need to add a user label, and read it when you press the button, then add the increment and re-write to it.
    Gerry
  1. Replies: 1
    Last Post: 09-11-2019, 04:42 AM
  2. Replies: 1
    Last Post: 02-05-2018, 07:46 PM
  3. Fagor 8020 Screen and axis problems. screen waving?
    By dirtrider23 in forum Fagor Automation
    Last Post: 12-17-2016, 03:06 AM
  4. WinCNC screen with lots of buttons
    By Harryman in forum WinCnc
    Last Post: 07-23-2013, 10:46 PM
  5. Replies: 2
    Last Post: 09-02-2011, 03:44 AM
