Re: Approximate machining time of the complex part
Originally Posted by
ralfg
Such a part can only be produced with at least a 5-axis milling machine. There are undercuts on the helix. CamBam cannot create the G-code for such parts and for 5-axis machines.
Why? I could rough the entire thing with a 3 axis machine and manual indexing. I see no reason it couldn't be done in s a single setup with a 4th axis. CamBam does not lend itself well to more than 3 axis machining, but its capable of it. Since there does not appear to be an undercut to deal with it seems like this could even be manually coded if you can't make your CAM software do the job.
I have a 4th axis, and I have manually indexing hardware.
I would probably 3D rough machine it with either manual or 4th axis indexing, and then manually program the cleanup passes on my 4th axis.
depending on exactly what this part is and what the tolerances are I might use an all manual machining, and fabrication approach. (grain or chip auger for example). For something a little more precise like a plastic injector screw I might use a manual lathe and a taper attachment, but I could use the 3D roughing and indexing, with a 4th axis cleanup for that too.
The image attached was 3D roughed, indexed, roughed again, run a simple series of profile cutes with indexing, and then manually polished on a manual lathe. Letting the robots do all the work isn't always the most efficient approach. I made about a 100 of these if I recall correctly.
Bob La Londe
http://www.YumaBassMan.com
