535,637 active members*
4,083 visitors online*
IndustryArena Forum > MetalWorking > Moldmaking > Arburg C4/b pneumatic injection
Page 1 of 2 12
Results 1 to 20 of 26
    Nov 2003
    154
    Anyone else running an Arburg C4/b pneumatic plastic injection machine?
    Anyone have a manual for it?
    Neuer Benutzer
    Feb 2013
    Arburg C4
    I have an Arburg C4 machine, it is the standard model with a stand and a large casting to hold the injection head. Arburg does not support these machines and it is hard to get info/manuals.
    JD
    Neuer Benutzer
    Feb 2013
    I Have one too, without manuals.
    But it is not so difficult.
    Heat the extruder, close the mold, press the injector down.
    Do you have special questions ?
    Nov 2003
    154
    Thanks for the response.
    No burning questions, have 2 of them running but always looking for a little more information on them.
    They run fine but can be finicky at times.
    Would really like to fine tune the mechanical pellet drop to get a little better metering. Tried to hook up a small water cooling system with certain molds but it did not work well as space is very limited.
    Neuer Benutzer
    Feb 2013
    It looks your machine is not complete original.
    I have maked some detail foto's of mine.
    The feeding machanism is a very smart 'mecanical' servo system.
    At this moment the machine is used in vertical position, injection thrue the middle of the mold.
    I am using it only for prototyping, so no problem with heating, always only a few products. Take is out by hand.
    Neuer Benutzer
    Feb 2013
    Arburg C4 Questions
    Hi
    A couple questions. What is the plastic bump on the U shaped plastic cover? With the clamp assy mounted vertical, what are using to close the mold. I cannot see any air cylinder?
    JD
    Neuer Benutzer
    Feb 2013
    nothing special, i think for opening.
    In this case the cylinder is under the table. ( mould injection through the center)
    Working of the feeder.
    When the plunger goes down, the lever operated and there is new granulate in the hopper aside.
    The further the piston is more granulate. The system adjusts itself when settings are right.
    Nov 2003
    154
    The bump is the handle so you can swing the cover open. If you do not have a cover the plastic drops all over the floor.
    I was going to saw before Hugo posted the pics that I could see his air cylinder was there because of teh large knuckle/toggle mechanism that operates the slide for the mold was in place.
    Also because of his set up to remove the plastic part Hugo is not running the machine in automatic mode with the ejection pins pushing out the parts. He is removing them by hand.
    Hugo do you have all the timers and electric components cabinit on the left side of the injection machine cabinet?
    Neuer Benutzer
    Feb 2013
    I do not have the original controller more.
    For the temperature I use an industrial controller.
    For the timer I have a microprocessor.
    I use it also in the other position, depending on the product.
    Because I usually make single pieces, I take the products by hand.
    Due to the modular concept you can do much experimenting with this machine.
    Neuer Benutzer
    Feb 2013
    Arburg C4
    Hi
    Thanks for the info. I thought the plastic bump might be an opening to manually insert plastic pellets. (I would like to be able to do that without removing the clear cover) My machine just has a "U" shaped cover. (no bump) Also after asking the question about the clamping method, I looked at the pic closer and saw the linkage to the air cylinder. I checked my files and I do have some paper copies of some of the pages of the Arburg C4S manual. This would be a pain in the neck to scan (each page individually) and I think Office Depot wants about 25 cent per page to make digital file. (PDF file) Not sure how good the scan would be since some of these pages are about 3 or 4th generation copies. The results may not be that good.
    JD
    Nov 2003
    154
    Here are a few shots of one in use.
    The parts are not perfect but about 85-90% once the settings are right.
    Neuer Benutzer
    Feb 2013
    arburg c4
    Hi Guys
    Does anybody know what this part for the Arburg C4 is and its function? I got in a box with the parts for my machine years ago, painted it and always wondered what is was for.
    JD
    Junior Member
    Apr 2012
    36
    Sorry to the original poster for hijacking the thread,ive been looking for info on this old machine i have and yours its the closest ive come across.
    i was told by somebody on line that mine would have had an hydraulic or pneumatic clamp set up back in its day,now looking at it and yours im not so sure,maybe its your model they were thinking of..thanks for posting the arburg.
    i should be using mine in a couple of weeks ive stripped it down serviced and repainted since these pictures were taken,im looking forward to seeing how it performs and i,ll have to keep an eye out for one of these arburg c-4-b now i know there out there.thanks
    Sep 2012
    I have managed to locate the user manual for this machine from a very kind chap! Anyone still after this?
    Nov 2003
    154
    Yes I am interested if you can post or send a digital copy.
    Junior Member
    Apr 2012
    36
    what is the max clamping pressure on the c 4b
  17. #17
    Nov 2005
    213
    Re: Arburg C4/b pneumatic injection
    I found this thread while searching for information on these machines which I inherited 2 of. I would love to have copies of any documentation you were able to locate. Happy to pay for xeroxing and postage, or labor to digitize if applicable. Please let me know if you can help! Thanks in advance.
  18. #18
    Dec 2015
    5
    Re: Arburg C4 Questions
    how can i remove the Cover from the Heat-Zylinder?
    MfG
    Andreas
  19. #19
    Nov 2003
    154
    If I remember right there are set screws to remove the whole cylinder from the machine. After removal from the machine you can loosen set screws from the top of the shield and take it off. I think the cylinder has a recessed groove in the top. The set screws hold the cylinder to the machine.
  20. #20
    Aug 2013
    4
    This thread is pretty old. Are you Arburg guys still out there? I just bought one off Ebay and will potentially need some advice.
Page 1 of 2 12
  1. Basic knowledge of injection mold and injection molding-4
    By vulcanmold in forum News Announcements
    Last Post: 11-10-2010, 05:23 PM
  2. Basic knowledge of injection mold and injection molding-2
    Last Post: 11-10-2010, 05:10 PM
  3. Basic knowledge of injection mold and injection molding-1
    Last Post: 11-10-2010, 05:03 PM
  4. arburg CPU card's schematic
    By clay_ldz in forum Safety Zone
    Last Post: 03-14-2010, 11:44 PM
  5. Help: Password for Arburg injection moulding
    By therock in forum Moldmaking
    Last Post: 11-30-2009, 12:02 PM
