585,886 active members*
5,631 visitors online*
    Sep 2022
    Arrow 2 Spindle Chiller
    Our Arrow 2 1250 has the 10K RPM spindle option. It does have a glycol heat exchanger for the spindle on the back of the machine but it's just a heat sink, no active phase change cooling like a chiller. We've measured spindle growth at 0.002" after running at max RPM for 30 minutes. Fives Cincinnati has confirmed this to be typical.
    Has anyone tried attaching a stand alone process chiller to their machine to control spindle growth?
    Thanks for looking.
    Mar 2011
    461
    All the older Arrows and Sabres had a chiller on the 10K spindles that worked fine once set up properly. Biggest issue I can remember is a lot of shops had the chiller temp set too low which caused excessive condensation in the spindle.
  1. spindle chiller ?
    By D.D.Machine in forum Sharp CNC
    Last Post: 03-17-2014, 05:34 AM
  2. Spindle chiller
    By splash in forum Bridgeport / Hardinge Mills
    Last Post: 08-15-2013, 12:22 PM
  3. Arrow 500 Chiller - Need a bleed or startup procedure
    By Larry Callahan in forum Cincinnati CNC
    Last Post: 03-25-2010, 03:21 PM
  4. Fadal 6030 spindle chiller
    By 5th-axis in forum Fadal
    Last Post: 10-24-2007, 12:55 PM
  5. Spindle Chiller Coolant
    By furnman487 in forum Fadal
    Last Post: 03-24-2006, 12:16 AM
