567,672 active members*
2,975 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Artificial intelligence AI with CAM
Results 1 to 12 of 12
    May 2006
    791
    Who or what cam system is doing anything with AI?
    Can I show the cam system a cad model and have it output Gcode?
    I have waited since the 1970's for this.
    Been doing this too long
    Moderator
    Apr 2003
    1353
    Re: Artificial intelligence AI with CAM
    We are doing this, but unfortunately it's not for the public at this time. Maybe once the patent is final I can talk more about this.
    Jun 2015
    3924
    hy bostosh if you have ideas, i would really like to hear them
    there is not such a " for everybody reliable program " yet, because there are many factors that are not easy to implement, especially for shops with parts and process high variations; in some production enviroments, things planned at 1st hour in the morning, may change a few times in the next 2-3 hours
    so existing automatization is there for less variable things :
    ... some conversational software can generate list of operations, starting from a custom blank shape, to a final part, as long as there is a solid tool registry with time consuming definitions that can match the list of needed operation; output list of operations is not yet considering tolerances, cutting specs are not adjusted with overhang, so is good only for simple rigid parts; the only thing that it does good is colision proof, until is needed to use a too big internal tool inside a small bore
    ... same idea as above, is taken a bit futher with mbd's for complex models, and uses cam tool library and operation register, and even can create a program for the cmm machine; even more, with generalistic file format, it can be optimized by your tool vendors with their specific tools, then sent back to you; it sounds so perfect, that almost noone uses it; i wonder why ?
    ... recognition software can scan :
    ...... a print and generate the solid
    ...... a real object and generate the solid by using custom feature recognition and faceting tools
    all above exists, but not used very much
    an intermediate aproach, that relatively gets some ground, is that of using predefined set of operations specific for each shop, in assocation with a predetermined feature format; this works as long as features are somehow identicall, then same strategy is aplied to them ( may be cutting, wire, etc ); this aproach fails when it no longer can identify some features as being associated with a strategy, thus main issue is with automatic feature recognition and association with strategy; in order for this aproach to work, is needed that solid files are in-house created, so to avoid compatibility isues with different file formats from other cam brands, or the way that other softwares defines features ... so this solution aplies to those that do their own product design, and in house machining, so, again, a very limited sector
    last but not least, are local custom solutions, as each shop has different needs, but how many shops go that way ? i know one example about custom solid&process declarations for a similar line of product, in such a way that automatized many repetitive tasks; downside is that requires skilled personal to be used, and also to have experience, in order to create the definitions as relieable as possible; another example that i just remembered us about toolpath recreation from g-code, and strategy change + reposting
    Identifiyng repetitive tasks is easy, while having the cam developer create a custom solution, is reserved only for big clients, while small ones can not aford the cost, so they are left with whatever parametization their current software allows; how reliable is that ? from this perspective, some use api, but this requires a more skilled programer than the usual cam programmer. I know an example of using api to create custom probing cycles, but this is only for a specific cnc brand, as there are many other ways to deal with probing. mr Dan B has his own take on api; if you are reading this, good luck, and may you finish soon and reach your goals
    For small tasks, there is vba and the like, which is frequently used at hobby level,
    last years, is not the ai cam that evolved, but conectivity; more and more programers realize the benefit of conecting to a cnc, and big plants are gathering machine usage infos ( cutting error waiting ) and plan preventive maintenance
    another idea that is pushed, is the digital twin / kindly
    Jun 2015
    3924
    and another example i just remembered, is by a cnc machine builder, simulating programs inside his software with accurate motion algorithms, so to fix or improve things, way before the real machine starts cutting; such algorithms are not available in cam softwares, or, if available, then very very limited
    conversational software for robots programing ( path programable by jog ), being able to solve automatically for incoherent movements
    so far, all are predictive, but there are also reactive applications, like robots that cut metal ( light cuts, not as heavy as a cnc machine ), and for repetitive tasks, they learn to autocorect position, thus to minimize deviation
    all listed examples are so unique, that having an AI performing as good as top programmers, seems a bit far away, but definetly closer than how it was in 1970 but at least in machining metal, programers can stay relaxed, as nowadays AI is busy with central bank digital currency
    mr bostosh, i want to thank you for a good advice that you give a few years ago : you said you craft those guitars at a shop ( you rent time, or something ), even if the machine is not yours, and the context was that is better to create a kind of trust enviroment, like not being needed to start on your own, but simply use what is allready available there and develop. I think it is a gold advice, as it teaches someone to not see an employer as a competitor, but a colaborator, like having a common goal, based on mutual respect / kindly
    May 2006
    791
    DeadlyKitten, and DanB,
    Lambda Function | Enabling Autonomous Precision Machining
    Check this site.
    "Today, machinists essentially use algorithms from experience; Adding AI is the natural evolution"
    Moderator
    Apr 2003
    1353
    It will be interesting to see what this can do, once you get past all the industry buzz words. Is this fully autonomous programming? Is there still human intervention required?
    Jun 2015
    3924
    indeed Dan, i also noticed the buzz-words, but no show-off maybe they wish to keep it under the hood
    there is this testimonial :
    ... This will be similar to launching Windows for the CNC machining industry
    also this features :
    ... AI-Assisted Generative Programming
    ... Real-Time Load Monitoring
    ... Real-Time Tool Life Monitoring
    ... Continuous Kaizen Insights
    ... Adverse Event Avoidance
    *okuma has them all
    the okuma controllor indeed is something, but more and more ohters are closing that gap
    the ones who will get out there the 1st relevant product, to cover efficiently most demands, will win, or at least have the 1st step advantage
    by relevant product, i mean those automated tools, that can make one programmer life much more easier
    in the end, is better to modify an unfinished solution ( thus spend time only corecting it where is needed ), rather than creating it full from zero / kindly
    Aug 2004
    771
    Adding AI to CAM is a fool´s dream or --
    someone like Elon Musk who can succeed in getting 20B$ in funding and 10 years of support for it to start working.
    It´s unbeliavably difficult to do good gcode,
    to do good cam,
    to do good parametric models for the cam to base on.
    May 2006
    791
    What would this following be defined as?
    "AI-Assisted Generative Programming" (sounds vague)
    Anything like automatic Feature Recognition?
    Where the system attempts to do features that it is programmed to recognize?
    Then seek human y / n verification.
    Jan 2005
    15331
    Quote Originally Posted by hanermo View Post
    to do good cam,
    You would not be using Parametric modeling, this is way behind, direct modeling is superior and has been used for more than 10 years checkout keycreator by Kubotek
    Mactec54
    May 2006
    791
    This is the real thing, since Cadkey19.........
    Back to AI......
    What can AI do within the cut to mod/improve the cutter usage?
    Jun 2015
    3924
    hy bostosh that was right from lambda page, please check attached
    it sounds vague, because it is abstractization at higher level; it's so generalized, that it may seem that will fail, but will not, if configured properly only for a specific process
    there are functions old, from decades, targeting CAD or CNC, rarely capable of doing both, as this requires having acces to motion algorithms
    let's narrow it to an example : okuma has adaptive function, but most common nowadays cnc don't have it ... so one could install hardware and record loads from machine, then change the program, mapping feeds where is needed; he may call such a tool as AI, or as IOT functions, does not matter
    nowadays, the term of AI on cam software, is more of a marketing thing, rather than actually boosting functionality at some unexpected / oau level
    parametric, Recognition, direct modeling
    for most shops, classical cad cam is king
    feature recogntion is used more in reverse engineerring, by some research labs, or kids in garages with some diy/cheap scanners, etc
    direct modeling is used more for parts for 3d printers, for stuff that the classical machining would fail, or be too expensive
    such new tools, are not there to drastically improve machining, but are more and more towards additive
    no one will fire his actual cam programmer, and get instead a 'direct modeling' guy ?!
    to do good cam,
    if you look at all things, is hard or impossible to find the common ground, thus a too generalistic aproach, seems out of comprehension, not possible to define now
    but look at the closer things, look at what is curently offered : those are not general functions, but more of customized approaches for imeadtly use
    if i may repeat myseld, AI today, in machining, is marketing, not something that will do your job / kindly
  1. Replies: 0
    Last Post: 03-31-2015, 06:55 PM
  2. Leisure and Learn(Business Intelligence)
    By cindylazz in forum Trade Shows / Webinars / Other Events
    Last Post: 08-05-2008, 10:05 AM
