545,577 active members*
7,222 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Assigning tooling to pockets using 21i-MB controls
    Jun 2021
    5
    I would like to know how to assign tooling to pockets on V-cnc 750.
    Is it through:
    -macro
    -parameter
    -under offsets/setting
    -m/c configuration
    When the machine goes to do a tool change. It doesn't look to be coming down close enough to the turret, to grab the tool. Which results in the machine dropping the tool. I was curious if that is because the reference point(G28 Z0) needs adjusted?
    Mar 2008
    103
    Re: Assigning tooling to pockets using 21i-MB controls
    Please contact technical support at 1-800-934-0735 (CINCINNATI) with your machine serial number; model type; and Control diagrams, from off the serial plate.
    We can discuss details and have a dynamic conversation; which will help you much quicker than 100 post or emails...
    GWood
  1. Replies: 4
    Last Post: 03-09-2020, 03:32 AM
  2. Assigning Variables
    By itstom in forum Fanuc
    Last Post: 02-24-2012, 10:52 PM
  3. Re Assigning Text Style
    By SPEEDRE in forum Autodesk
    Last Post: 05-17-2011, 02:28 PM
  4. Nl assigning temporary C zero.
    By macca22 in forum Mori Seiki lathes
    Last Post: 12-10-2009, 01:22 AM
  5. tooling priority in fanuc controls
    By inflateable in forum Fanuc
    Last Post: 05-02-2007, 08:11 AM
