600,838 active members*
3,321 visitors online*
Results 1 to 7 of 7
    Nov 2024
    Atc on kryle vmc700c fanuc om
    Hello,
    I have an issue here with the two buttons atc.
    When I press the atc button the umbrella 20 tools goes left and right and then 1024 alarm.
    I did a zero on 4 axis on the 1 tool position.
    I go to the diagnostics and on d0320:0007 d0322:005 d0340:0020 d0342:0016 d0344:0010 d0360:01 d0361:01 d0362:01
    How can we do the atc buttons to go correct tool by tool left or right?
    Also the umbrella has an encoder A like on the photo.
    Help!!
    Attached Thumbnails Attached Thumbnails 1742890081819163404288471694492.jpg   17428900955395180170890958357105.jpg   17428901151432830578422989975535.jpg
    Nov 2024
    Quote Originally Posted by Dista View Post
    Hello,
    Help!!
    Here is the A encoder on umbrella
    Dec 2008
    3185
    The 'A' in the control is usually the rotation axis around the 'X' axis
    You may find that 'A' has no relationship to the tool caurosel
    Do you have a rotary axis on the machine ?
    Nov 2024
    The A axis on me is a encoder on the umbrella and is count the position on umbrella. We have the motor with his encoder but I have extra encoder at the top on umbrella.
    Nov 2024
    Here is the 20 tool
    Nov 2024
    Re: Atc on kryle vmc700c fanuc om
    I also put 9001 9003 programs.
    on mdi T1 M06; the cnc does spindle orientantion lock unclamp the tool and stay there.
    The two buttons ATC when i press one of theme the cnc does left right left right and some times 1026 alarm.
    Where is the truth?
    Nov 2024
    I realise that from the tool 1 to tool 2 manual by hand the A show on the pos 0.800 . When i press the atc to go from one to the second tool the A on the pos show me 0.534 aproximatly.
    How to solve this??
  1. adjusting tool changer kryle vmc700c
    By joachim in forum DNC Problems and Solutions
    Last Post: 03-28-2025, 06:05 PM
  2. Kryle vmc700c k30831 parameters
    By Dista in forum Fanuc
    Last Post: 02-13-2025, 02:03 PM
  3. Tool changing on Kryle VMC500B - Fanuc 0M
    By calor in forum DNC Problems and Solutions
    Last Post: 04-25-2005, 08:04 AM
