584,802 active members*
4,984 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > ATC on my PCNC1100 not referencing
    Exclamation ATC on my PCNC1100 not referencing
    Hi Guys,
    Second issue on my PCNC 1100.
    When I try to reference my ATC , it rotates once and when the magnet is on the reed switch it starts to shake like it is not registering the sensor.
    Sometimes this will go on for seconds, other times minutes before I get the error that says "ATC I/O failure"
    My USB cable was damaged so I replaced it. (It arced through to the main body, cable got pinched somewhere)
    I rebooted. Made sure the sensor is clean of any debris.
    Would you recommend I update PathPilot because the software on my PC is old.
    Any other areas I can investigate?
    Cheers
    Juan
    Jun 2005
    1723
    Re: ATC on my PCNC1100 not referencing
    If your usb cable arc’d through the insulation you probably destroyed some chips on the controller
    Russ
    Exclamation Re: ATC on my PCNC1100 not referencing
    Thanks Russ,
    I found a loose connection at the 20 pin connector located above the servo motor of the ATC. The actual referencing pins were not making proper contact.
    With that sorted, I now have another issue with an error "ATC Button - USB command Rejected"
    So the cables and boards seems fine. All other commands get processed e.g. draw bar up and down, air blast on and off.
    But to bring the tray in or to rotate one position, the ATC needs to reference itself first. By choosing any of the mentioned options, the ATC will do a full rotation and stop in the correct position (magnet on the reed switch) and then gives the error.
    I searched the cnczone and found a very similar error from someone else's post
    https://www.cnczone.com/forums/torma...-software.html
    It seems like updating the PP will be a good option.
    Cheers
  1. WTB Atc for PCNC1100
    By mendez in forum Tormach Personal CNC Mill
    Last Post: 05-12-2020, 05:04 AM
  2. Referencing axis at 0.0
    By Mike 1948 in forum Mach Software (ArtSoft software)
    Last Post: 01-09-2015, 06:21 PM
  3. Referencing axes
    By dsnaith in forum Machines running Mach Software
    Last Post: 11-04-2012, 04:49 PM
  4. Zero Referencing
    By br1 in forum Mach Mill
    Last Post: 03-05-2009, 01:17 AM
  5. Referencing of C-axis
    By lolo26 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 08-25-2008, 08:55 PM
