600,838 active members*
3,321 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Auto Rotary Brake Parameter
Results 1 to 18 of 18
    Feb 2007
    71
    I've had my Main-Parms-CTRL Auto Rotary Brake set to yes since I installed my 4th axis on my RH19 Cent7. After getting my Fusion 360 post processor to spit out code for full 4th axis machining and not just indexing, I ran a test program. The 4th axis moves were constantly stopping waiting for the brake to turn on or off. After setting the Auto Rotary Brake parameter to no, the program ran smoothly. But.....
    When I put the machine in handwheel mode and the 4th brake was on, you could turn the 4th axis dragging the brake. I'm a little concerned that accidentally ordering the 4th axis to rapid to different positions with the brake on could be a bad thing.
    When running a F360 program that indexes the A axis, it leaves the clamp on.
    Any thoughts/suggestions on this?
    Regards
    And Hope you all have a Happy New Year!
    James
    Feb 2007
    71
    Re: Auto Rotary Brake Parameter
    Here's the sample program that F360 spit out:
Name:	4th Simulation.jpg
    O1002
    (T7 D=0.125 CR=0.01 - BULLNOSE END MILL)
    N10 G90 G94 G17
    N20 G20
    N30 G32
    (2D CONTOUR25)
    N40 M0
    (MANUAL TOOL CHANGE TO T7)
    N50 S6112 M3
    N60 G17 G90 G94
    N70 G540
    N80 M11
    N90 G0 A309.889
    N100 M8
    N110 G0 X-20.4125 Y0
    N120 G43 Z1.3254 H7
    N130 G0 A309.889
    N140 Z0.9254
    N150 G1 Z0.7504 F3
    N160 Z0.4002
    N170 X-20.413 Z0.3887 F7.3
    N180 X-20.4146 Z0.3772
    N190 X-20.4173 Z0.366
    N200 X-20.4209 Z0.355
    N210 X-20.4256 Z0.3445
    N220 X-20.4312 Z0.3344
    N230 X-20.4377 Z0.3249
    N240 X-20.4451 Z0.316
    N250 X-20.4533 Z0.3078
    N260 X-20.4622 Z0.3004
    N270 X-20.4717 Z0.2939
    N280 X-20.4818 Z0.2883
    N290 X-20.4923 Z0.2836
    N300 X-20.5033 Z0.28
    N310 X-20.5145 Z0.2773
    N320 X-20.526 Z0.2757
    N330 X-20.5375 Z0.2752
    N340 X-20.55
    N350 G93 X-20.5532 A309.801 F2003.6
    N360 X-20.5562 A309.541 F1719.8
    N370 X-20.5588 A309.127 F1603.2
    N380 X-20.5608 A308.588 F1602.6
    N390 X-20.5621 A307.96 F1719.8
    N400 X-20.5625 A307.287 F2003.5
    N410 A128.29 F8.5
    N420 A52.714 F20.2
    N430 X-20.5621 A52.04 F2003.5
    N440 X-20.5608 A51.413 F1719.8
    N450 X-20.5588 A50.874 F1602.6
    N460 X-20.5562 A50.46 F1603.2
    N470 X-20.5532 A50.2 F1719.8
    N480 X-20.55 A50.111 F2003.6
    N490 G94 X-20.5375
    N500 X-20.526 Z0.2757
    N510 X-20.5145 Z0.2773
    N520 X-20.5033 Z0.28
    N530 X-20.4923 Z0.2836
    N540 X-20.4818 Z0.2883
    N550 X-20.4717 Z0.2939
    N560 X-20.4622 Z0.3004
    N570 X-20.4533 Z0.3078
    N580 X-20.4451 Z0.316
    N590 X-20.4377 Z0.3249
    N600 X-20.4312 Z0.3344
    N610 X-20.4256 Z0.3445
    N620 X-20.4209 Z0.355
    N630 X-20.4173 Z0.366
    N640 X-20.4146 Z0.3772
    N650 X-20.413 Z0.3887
    N660 X-20.4125 Z0.4002
    N670 G0 Z1.3254
    N680 M9
    N690 G32
    N700 M11
    N710 G0 A0
    N720 G28 G91 X0 Y0
    N730 G90
    N740 M30
    Sep 2010
    535
    Brakes on the rotary are for heavy milling in place, so acting like an indexer. Move to 90º and do the face operations, then to 180º and so on. If you are using the fourth axis as a true simultaneous 4th, then you would leave the brake off as it's moving any time in A axis. Your cuts should be lighter and hopefully there is no large amount of backlash in the 4th. You usually have a 90:1 ratio on the worm and then 2:1 or maybe even 3:1 on the belt drive, so you get a lot of strength against cutting forces just by the gear reduction ratios.
    Feb 2007
    71
    I still question if there's any kind of setting through the Milltronics system that would keep the A axis from turning when the brake is on. Now that I've set the Auto Rotary Brake parameter to NO
    From the "7000 Series CNC Programming ManualMN-72-1"
    Yes will control the rotary brake on A and B axis automatically. This brake shuts off before rotary moves, and it turns the brake back on when the move is complete. No requires M10/11 and M12/13 to turn the brake off/on. Note: power needs to be cycled when this parameter is changed.
    Considering that the power has to be cycled after the parameter has changed makes me think that this can't be switched on and off by modifying the post to edit the Byte Parameter #397 Auto Rotary Brake when I run a F360 generated program. If you look at the above program, you can see there are several A axis moves to accomplish what I would hand program on the machine in one line with the auto brake left on. Reason being that F360 uses radius lead in and lead outs including the rotary moves during lead in and out.
    Sep 2010
    535
    Well, is your Centurion 7 the same as the 7000 series? If so, it sounds like setting the parameter to yes will take the brake off when rotating and put it back on when stopped. If you tried that and it doesn't work, then you would have to go and set it to No and then edit your post processor to add in the brake release, M11 before any A axis move and M10 to engage the lock when there aren't any A axis moves on the next line. M10/11 is based on the Centurion 5 software... I don't have the manual for Centurion 7 machines.
    Feb 2007
    71
    Maybe I haven't explained my self very well. I'm looking for an uninterrupted cutting motion making a great machine finish that will still need a day or more of hand polishing. Any little divot caused by the cutter dwelling waiting for the brake to cycle on and off will add hours to finishing my project.
    Quote Originally Posted by gunmaker View Post
    Here's all the A axis moves isolated from the program. Each one making a divot.
    N410 A128.29 F8.5
    N420 A52.714 F20.2
    Sep 2010
    535
    Well, it sounds like you found your solution, don't use the brake...
    Feb 2007
    71
    It does run smoothly but it makes it a pain in the ass to have to MDI M11 to position the rotary axis with handwheel or jog function.
    I wonder if there is a way to edit the macro for the jog and handwheel function that would add M11 and M10 so it doesn't drag the brake if I forget to turn it off....
    Sep 2010
    535
    Seems to me set to no should make any A axis movement, programmed or MDI/Jog be without the brake on. If that's not the case, then contact Milltronics and ask them.
    Feb 2007
    71
    end of a simple F360 indexing program leaves the brake on
    N2960 M9
    N2970 G32
    N2980 M11
    N2990 G0 A0
    N3000 M10
    N3010 G28 G91 X0 Y0
    N3020 G90
    N3030 M30
    Mar 2019
    51
    Edit your post processor then.
    Sent from my SM-N960U using Tapatalk
    Feb 2007
    71
    Quote Originally Posted by cbChris View Post
    That still doesn't address the ability to jog with the brake on.
    Mar 2019
    51
    Edit your pp to turn off the brake at the end of a program, then it will always be off unless you specifically turn it on.
    Feb 2007
    71
    Still curious what other Milltronics owners that run a 4th axis do with their setup/parameters.
    I still haven't checked if the brake is left on and powered down, if the brake will still be on when the machine powers up and goes through the homing sequence.
    You are correct your brake should be releasing when handwheeling (or jogging) the A axis. From what I remeber, handwheeling (or jogging) the A axis would always release the brake (regardless of auto-roratry brake parameter being on of off) Talk to Milltronics service. It's possable you need a software update...
    I'm working on hooking up my new rotary. What are the small red and black wires going to on yours?
  17. #17
    Feb 2007
    71
    Probably related to the air brake servo, or maybe home sensors
  18. #18
    You were correct. Air brake servo. thanks. I was thinking I had to install a solenoid valve in the electrical cabinet.
  1. Replies: 6
    Last Post: 12-29-2023, 06:29 PM
  2. Haas ec 1600 rotary platter brake drum leak
    By nitishlal in forum Haas Mills
    Last Post: 09-29-2019, 11:21 AM
  3. 600mm Box bend brake (Finger Brake, pan Brake)
    By RotarySMP in forum Bending, Forging, Extrusion...
    Last Post: 11-01-2015, 10:24 AM
  4. parameter to enable auto operation with edit key on??
    By chris.spencer in forum Mori Seiki lathes
    Last Post: 07-24-2014, 03:31 PM
  5. Rotary Broaching Brake
    By florida in forum News Announcements
    Last Post: 10-08-2012, 01:48 PM
