504,064 active members
5,709 visitors online
    May 2019
    4
    auto zero touch plate
    Is there any calibration that needs to be done on the corner finding touch plate? I am using Mozaik software and the flip parts the tenions do not line up. Mozaik says that the sheet is miss aligned. I ran a test with v carve pro created a tool path in the center of the sheet 24in on the x axis and 48 in on the y and a 1/4 in bit. I ran the tool path and it was 1/4 in off on the y axis. I moved the sheet a 1/2in out of square with the table on 1 side ran the tool path again and it was a 1/2 in off the previous mark. Any suggestions?
    Feb 2005
    744
    Re: auto zero touch plate
    I assume you are using the corner finding routine with your tool to find the corner of your material correct?
    The corner finding routines i have used in the past find the center of the endmill in realation to the touched off faces, you then have to manually move the zero 1/2 the endmill diameter to be on the true material corner.
  1. Z Auto touch plate earthing / grounding issue
    By DeanR181 in forum General Other Machine Discussion
    Last Post: 10-16-2017, 11:52 PM
  2. how to connect a touch plate to auto-zero z-axis
    By Ivano in forum Australia, New Zealand Club House
    Last Post: 06-18-2017, 10:15 AM
  3. Auto Z Touch Plate
    By kaetamer in forum CNC Router Parts
    Last Post: 04-12-2014, 04:34 AM
  4. Auto tool setter / touch plate ?
    By chrisnis in forum Machines running Mach Software
    Last Post: 04-06-2013, 12:24 AM
  5. Tormach Auto Z Zero Touch off Plate??
    By BigChad in forum Tormach Personal CNC Mill
    Last Post: 09-22-2011, 03:18 AM
