534,976 active members*
3,496 visitors online*
IndustryArena Forum > CAD Software > Autodesk > AutoCAD - Need Extrude via Loft
Results 1 to 4 of 4
    Jan 2021
    5
    Hello;
    I am needing to extrude an inner and outer ellipse so as to subtract the inner extruded ellipse later, BUT what I really want to do is Loft the inner and outer ellipses so they taper to the other end which are circles. I can loft both ellipses, but when trying to subtract, it seems that shell was only extruded during loft, not like when doing a regular extrude, so subtracting doesn't work.
    Any ideas ?
    Mar 2003
    35279
    Re: AutoCAD - Need Extrude via Loft
    LOFT has an option for solid or surface.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Dec 2003
    827
    I'm very rusty with Autocad and haven't used the most recent versions,so I might be wide of the mark here.Don't they use some weird term for extrude?Would it be feasible to create the outer and inner objects on different layers and then do a Boolean subtraction of the inner?
    Jul 2011
    295
    I have not used in autocad in a long time. The command you might want is called draft. It puts a slope on things.
  1. Loft in XR8
    By sudsy in forum OneCNC
    Last Post: 12-29-2020, 08:18 PM
  2. Why can't I loft cut?
    By Analias in forum Alibre Design
    Last Post: 11-27-2012, 10:36 AM
  3. Can anyone help me use the loft boss...
    By cloverfield333 in forum Solidworks
    Last Post: 07-24-2009, 11:14 PM
  4. my college loft
    By zachjowi in forum General WoodWorking
    Last Post: 01-21-2008, 04:38 AM
  5. modifying a loft
    By PTcutter in forum Solidworks
    Last Post: 06-18-2005, 01:22 AM
