586,000 active members*
4,834 visitors online*
    Avid CNC New touch plate dimensions
    Hi everyone,
    I own a legacy version of the Avid CNC, a 48x60 CNCRP. I recently updated to the Mach4 version and I see that with the new touch plate (the square version) I can set not only Z, but X and Y zeroes. I was wondering if anyone could share the dimensions of the new square touch plate, I think I can 3D print it and use the old cables/connector.
    The Avid CNC website only has the dimension of the copper touch plate, but not the aluminum housing.
    Thanks in advance.
    Carlos.
    Jul 2015
    33
    Re: Avid CNC New touch plate dimensions
    I have this and can check later; you're looking for the 'interior' dimensions of the touch plate area itself right?
    Jul 2015
    33
    It's 56mm x 56mm interior, and 72mm x 72mm exterior dims - some info found here: https://www.avidcnc.com/auto-z-and-c...ate-p-288.html
  1. CNC RP/Avid Touch Plate
    By wmgeorge in forum Avid CNC
    Last Post: 04-12-2023, 06:11 AM
  2. Replies: 3
    Last Post: 08-04-2020, 10:32 PM
  3. CNC Router Parts / Avid Touch off Plate
    By wmgeorge in forum For Sale Only
    Last Post: 08-04-2020, 01:05 PM
  4. Replies: 5
    Last Post: 07-16-2020, 03:35 AM
  5. K2 CNC touch plate
    By lumenire in forum K2CNC
    Last Post: 10-06-2017, 03:47 PM
