567,778 active members*
2,539 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > For Sale Only > Avid/CNCRP PRO4824 with NEMA34 / 2.2 spindle / leg kit - Austin, TX
    Apr 2009
    This machine has been great but hasn't been used enough to justify the space and money that can be put to other projects. I am asking $8500 and not open to selling any parts separately. I am located in Austin, TX and am would prefer local pickup.
    1 x PRO4824 4' x 2' CNC Router Kit
    * Version: Nema 34 Compatible
    * Z*Axis Travel / Gantry Height: 8" / 8"
    1 x Leg Kit (PRO CNC)* Size: 4' x 2'
    1 x Plug and Play NEMA 34 CNC Control System
    * Cable configuration: (1) 12' and (3) 20' cables [recommended for 4'x'2' or 4'x4' machines
    * Additional Motor Drive: +1 [5th*Drive Upgrade]
    1 x Pepperl + Fuchs Proximity Sensor Kit
    * Sensor Configuration: Homing/Limit 6 Sensor Kit
    1 x Tramming GMT Spindle Mount
    1 x PC892 CNC Router Mount
    1 x 2.2 kW Plug and Play Spindle / VFD System
    1 x ER20 Collet Set 1/8", 1/4", 3/8" w/ (3) Balanced Nuts
    1 x Daedalus NL330 CNC Dust Shoe, 80mm, Red
    Mar 2023
    Re: Avid/CNCRP PRO4824 with NEMA34 / 2.2 spindle / leg kit - Austin, TX
    Is this still available? How can I get in touch with you?
    Community Moderator RaderSidetrack's Avatar
    Apr 2018
    62
    Quote Originally Posted by Brads View Post
    I recommend using the PM function to send a message to member elbarnso.
    Click his MemberID in post #1 and then choose "Private Message".
  1. FS: Avid CNC / CNCRP PRO4824 full set up
    By dzsflw in forum For Sale Only
    Last Post: 08-26-2022, 05:34 PM
  2. Wanted: Avid CNC / CNCRP Benchtop PRO 2424
    By salvagedcircuitry in forum For Sale Only
    Last Post: 06-04-2020, 07:07 PM
  3. Replies: 4
    Last Post: 02-08-2020, 03:28 AM
  4. CNCRP plug and play kit - Spindle connection
    By Baloo70 in forum Avid CNC
    Last Post: 07-05-2018, 03:08 PM
