585,719 active members*
4,368 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Avid touch plate occasionally moves spindle up
Results 1 to 6 of 6
    Jul 2017
    Looking for suggestions: I have a 2 years old CNCRP Pro 4848 with stock plug and play Nema34 system and spindle.
    I occasionally have a problem when changing bits. When I hit hit auto zero button in Mach3, the spindle slowly raises, instead of lowering. Sometimes the spindle will slowly lower but stop before the bit hits the plate, acting like it does when operating properly but not actually touching. If I shut down Mach3 and reinitialize it works. I just hate doing that in the middle of a job.
    Any thoughts?
    Mar 2003
    35538
    Re: Avid touch plate occasionally moves spindle up
    Could be a problem with your Mach3 installation.
    Could be a problem with your Auto Zero macro.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2005
    1740
    Quote Originally Posted by mgaylo View Post
    Any thoughts?
    Mach3 has little quirks. Others will say not , switch over to Mach4 and I am assuming your using Warp9 ESS.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
    Jul 2017
    Quote Originally Posted by wmgeorge View Post
    Thanks for the suggestion. I’ve been thinking about upgrading to Mach4, maybe I’ll take the plunge.
    Jan 2014
    29
    I wouldn't purely blame it on Mach3. I now do run Mach4 however.
    That being said I have pretty much the same setup you do and have never encountered what you describe.
    It could be the setup of your software but isn't purely because it is mach3.
    Aug 2016
    122
    That's really strange. Now, if you jog right after that, does everything work like it should? If so, I'd have to take a look at that autozero routine to see what it is doing. I wrote my own routine for zeroing when I used Mach 3 (a modified version of one of several out there). I never encountered anything like you describe. I recently upgraded to Mach4. I was all set to get to work writing my own and discovered that the Avid install has a Z zero option that works great. I was using my own plate that I made and it worked fine. Birthday Santa brought me an Avid touch plate and I just started using it the last few weeks and I really like it. My plate was a little crude and my corner finder setup was even more so, but it worked.
    You might try creating your own button and routine and see what happens. Or study the routine (script/macro/whatever) and try and understand what and why.
    Good luck. Let us know if you figure it out. I'm curious.
    On the Mach 4 upgrade...No issues with it and I like the format a little better. Took a little time to get used to the "new," but Its familiar to me now. My biggest hurdle was the programming. Very different. Lots of help over on the Mach 4 forums though. I have several buttons I created to do simple tasks like park, move to the spot I like for tool changes, raise the Z all the way up to get it out of the way, move to work 0, etc.
    Tony
  1. CNC RP/Avid Touch Plate
    By wmgeorge in forum Avid CNC
    Last Post: 04-12-2023, 06:11 AM
  2. Replies: 11
    Last Post: 09-30-2020, 05:42 PM
  3. HSD es 919 Spindle Touch Plate problem
    By MikeCaffey in forum Spindles / VFD
    Last Post: 09-11-2018, 10:21 PM
  4. Z2 Height Touch Plate w/o spindle wire
    By TTalma in forum DIY CNC Router Table Machines
    Last Post: 04-11-2018, 01:07 PM
  5. Replies: 12
    Last Post: 06-05-2013, 06:05 PM
