540,744 active members*
7,698 visitors online*
    Mar 2021
    AXBB-E Controller and Closed Loop Nema 34 Motors
    Folks,
    I have searched the internet for this information but have come up short each time. Sorry if I missed the proper key words!
    I have an AXBB-E and I am attempting to use it with the UCCNC controller software. Currently everything is running fine but I have followed the instructions from the drivers (CL86Y, StepperOnline) and the controller. I haven't found an answer to is whether I should use isolated outputs or non-isolated outputs for the PU and DR wiring. My plan is to use this for routing and plasma cutting, thus my reason for thinking I want to use isolated ports. While all the documentation shows I should use non-isolated ports, they aren't specific to a plasma system and closed loop system. Would using isolated ports help with high frequency feedback from the Plasma Cutter?
    At this time my Z-Axis is not closed loop and I don't see the need to use isolated ports because I don't have a Torch Height Control module and it will only be used when routing.
    I asked the vendor I bought the controller from and they suggested I buy an upgraded controller but they also stated it was possible to use what I bought but it would involve much more wiring and that I needed to get the details from StepperOnline. StepperOnline sent me the manual that came with the drivers.
    Thoughts?
    Regards,
    Greg
    Nov 2013
    1118
    Re: AXBB-E Controller and Closed Loop Nema 34 Motors
    most stepper driver have photodiode/photocoupler inputs for step/direction/enable already.
    Isolated inputs are nice but I don't think they are a game breaker.
    Craig
    Mar 2003
    35454
    From the AXBB-E manual
    8.1.2
    Digital non-isolated ports.
    Port#1 pins 9. to 17. are non isolated outputs. These outputs are referenced to the 0Volt (ground) of the 5V power supply.The outputs can push/pull 20mAmps current maximum with TTL (0/5V) voltage level.The purpose of these pins are to output step and direction or other high frequency signals which require no isolation
    You're wiring these outputs to drives that already have isolation, so there's no reason to use the isolated outputs on the AXBB-E.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Replies: 3
    Last Post: 12-11-2020, 02:46 AM
  2. Nema 34 closed loop driver alarm problem(HBS86H)
    By Lnt in forum Stepper Motors / Drives
    Last Post: 02-28-2020, 04:24 PM
  3. NEMA 23 Closed Loop Stepper Motor System-Hybrid Servo Kit
    By automationtechinc in forum Automation Technology Products
    Last Post: 07-22-2018, 05:53 PM
  4. Closed loop servo vs real close loop in motion controller
    By ciufuliciboy in forum Servo Motors / Drives
    Last Post: 04-21-2018, 04:36 AM
  5. Replies: 10
    Last Post: 04-09-2018, 07:05 AM
