554,025 active members*
2,969 visitors online*
    Oct 2018
    10
    Axcess will not reverse with homing/limits check box
    Hi All,
    Thought I was getting pretty good at Mach3!
    I just replaced my ancient PC and moved to an old PC plus UC100, loaded my configurations XML but now the Y Axis is backward (everything else is right).
    I have tried reversing my Y Axis a couple ways: Reversing the Homing/limit tab check box and Toggling Dir +/- (general)
    Background: This is a Chinese "IND_CNC" ("industrial cnc") which has been great for years. It is a large (5'x10') gantry machine with 2 Y axis motors. Since it worked for years as is, I have a bias against digging into the control and switching motor wires.
    When I reverse the X axis via the homing/limit tab it immediately reverses, same with Z.
    Does anyone know what might be preventing the Y axis from reversing in software?
    Thank you for your thoughts!
    David
    Nov 2012
    1218
    Re: Axcess will not reverse with homing/limits check box
    Is the Y axis moving backwards while jogging too, or only while homing?
    If the axis jogs in the wrong direction, then change Config - Ports and pins - Motor outputs - Y axis - Dir LowActive.
    Oct 2018
    10
    Yes Y Jogs in the wrong direction, runs a program in wrong direction. Y is just flipped. I will try this, I think I already did but I will report back. Thank you!
  1. Homing and Limits... new machine.
    By adam_m in forum DIY CNC Router Table Machines
    Last Post: 01-25-2014, 09:59 PM
  2. Setting up Config >Homing/Limits Dialog (Motor Home/Soft Limits)
    By CStevens6 in forum Mach Software (ArtSoft software)
    Last Post: 07-18-2013, 04:19 AM
  3. HELP! Limits and homing are killing me!
    By stagefivedrift in forum Mach Mill
    Last Post: 10-26-2010, 04:37 AM
  4. Need Help with homing and limits
    By ratpack in forum Mach Plasma / Laser
    Last Post: 04-28-2010, 05:31 AM
  5. Help with limits not working when homing
    By dave70 in forum Mach Mill
    Last Post: 03-22-2007, 05:46 PM
