600,786 active members*
3,088 visitors online*
    Mar 2025
    Axis A: Feedback missing
    Hi! I got a primero milling machine with an 4th Axis. Lately while booting I got an error Axis A: Feedback missing. The servodrive is fagor axd 1.15-s0-o-b. I could not find what causes this message in order to solve it. The 4th axis is no longer working.
    Nov 2013
    4961
    Re: Axis A: Feedback missing
    I'm not familiar with Fagor or the particular servo drive, but all servos require feedback, usually in the form of an encoder that feeds back into either the drive or the motion control.
    It is by virtue of that feedback that the servo 'knows' where it is. In absence of that signal most servos will drive at full speed one direction or another, a run-away, until it slams into
    a stop, often doing damage as a result. As a consequence of the risk most motion controls have a means of detecting the presence or absence of the encoder signal. Should it be absent
    it will as a matter of safety shut that axis down altogether.
    It sounds like the feedback device, be it a resolver or an encoder is faulty or the wiring is broken/loose. That is where I would start.
    Craig
  1. Y axis not reference - missing home switch on current axis
    By mits007 in forum Mach Software (ArtSoft software)
    Last Post: 05-28-2020, 11:13 PM
  2. axis enable missing / DB35 DBX2.1 is missing
    By Max2000 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 06-13-2019, 06:54 AM
  3. Z axis motor feedback
    By atalon in forum Stepper Motors / Drives
    Last Post: 01-01-2015, 09:59 PM
  4. Help! Problem with Axis Feedback
    By Hector.lemac in forum Bridgeport / Romi Lathes
    Last Post: 05-30-2013, 09:44 PM
  5. Feedback on a Z-axis drive
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-11-2008, 05:19 PM
