Hi
after a lot of reading, head scratching and editing, I have made an edited Fanuc 4axis post work with an Phillips control on an MAHO 800C. Made new canned drill cycles for the control, and deleted a ton of Fanuc code. Made a dovetail fixture and milled the first test part yesterday, using G58 as vertical machining on the top of the part, and G59 for the indexing in horizontal milling. the machine can change between the two configurations with an M code.
I used an old vertical post to program the top side of the part, as the post changes XYZ to XZY for vertical milling, and had to rotate the part 180 degrees to get it right when I was milling horizontal with the new post.
the question is if it is possible to create an axis combination where I switch XYZ to XZY and rotate the coordinate system in the machine configuration, so I can do all this work with one post and Mastercam file?
If so I would like an input how to do so?
I have been thinking on how to do this for a week now, and I am hoping someone can help me a bit with this.
Cheers, Daniel
