548,681 active members*
2,198 visitors online*
IndustryArena Forum > WoodWorking > General WoodWorking > Ball Nose Upcut vs. Downcut
    Jun 2008
    18
    I was about to start doing some 3D cutting and needed some bits. I am seeing that I have options for Up and down cut. As long as I am doing a roughing cut first, does it really matter?
    Apr 2004
    5421
    Re: Ball Nose Upcut vs. Downcut
    Up-cut is standard, because it evacuates the chips. Down-cut is used when you're cutting plywood or laminates and want to avoid pulling up chips in the top veneer. If you're running a roughing pass first, that's not going to be an issue, so go with the up-cut bits.
    Andrew Werby
    Website
  1. Using Ball Nose EM
    By Atomic_Sheep in forum Wood Working Tooling
    Last Post: 09-08-2019, 10:10 PM
  2. Ball nose Bits
    By zmiller627 in forum CNC Tooling
    Last Post: 09-03-2013, 06:14 PM
  3. Bull nose or Ball nose
    By jcnewbie in forum Mastercam
    Last Post: 02-22-2010, 12:35 AM
  4. What type of ball nose to use?
    By gorby in forum CNC Tooling
    Last Post: 12-10-2009, 10:34 PM
  5. Ball Mills Vs. Round Nose
    By Cartierusm in forum DIY CNC Router Table Machines
    Last Post: 03-11-2008, 03:20 PM
