529,698 active members*
2,152 visitors online*
IndustryArena Forum > General Manufacturing Processes > Milling > Ball screw nut selection , help please.
    Sep 2020
    Hello ,
    I am building a CNC mill with tight tolerances and best components available.
    I am using C3 ground ballscrews by TBI .
    Professional input is much appreciated.
    My vendor suggested me using a single ball nut with medium preload whereas I have come across professional machines using ground ballscrew with double nut bellivelle washer configuration.
    While I understand the geometries of contact in both cases.
    My plea to go with double nut both slightly preloaded would be to eliminate any micro errors on ball surface itself even though coming at price of more friction and wear but shouldn't worry me since using big servos on all axis.
    I wonder if vendor has a valid point as opposed to what I found on professional VMC's.
    Thanks.
    Banned
    Sep 2020
    8
    Re: Ball screw nut selection , help please.
    Thank you for sharing!
  1. Ball nut arbor size for 1605 ball screw
    By kdoney in forum General MetalWork Discussion
    Last Post: 04-08-2020, 07:45 AM
  2. Double ball nut worth it for long C7 grade rolled ball screw?
    By salukikev in forum Benchtop Machines
    Last Post: 02-21-2020, 05:18 AM
  3. Adding ball screw to lathe for Electronic Lead Screw
    By harrzack in forum Hobbycnc (Products)
    Last Post: 12-28-2018, 03:28 PM
  4. Z axis to ball screw or not to ball screw
    By brian257 in forum Bridgeport / Hardinge Mills
    Last Post: 03-28-2012, 09:39 PM
  5. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
