585,589 active members*
2,954 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Battery Change Utility OSP-7000L
Results 1 to 6 of 6
    Nov 2013
    7
    I have an OSP-7000L control lathe that I need to change the batteries in and I have the battery change utility on a floppy disk, however we changed out the floppy reader with a usb reader (emulator?).
    Does anyone know how I can get the Battery Change utility from the floppy onto a thumb drive?
    I did try to use the OSP reader program ver. 2.2.0.1 to transfer battery change utility from floppy disk to a thumb drive but I am not having any success. Is there instructions as to how to use this program or maybe if there is an English version that I might understand? any help will be greatly appreciated!
    Mar 2012
    15
    Re: Battery Change Utility OSP-7000L
    try this tool to make a image from floppy and put a image back in usb with free usb tool
    Nov 2013
    7
    Thank you,
    I will try this, I ended up switching it back to floppy drive just so I could get the batteries changed before I lost everything, I will give this a try and see if it comes up like it should, Thanks again!
    May 2009
    41
    You shouldn't have an issue changing the batteries with the machine powered up.
    I had mine out the other day to check them.
    Obviously play carefully around high voltages with machine powered up.
    Nov 2013
    7
    ok, thank you.
    Mar 2012
    15
    Quote Originally Posted by gibsoni View Post
    you change and reset battery alarm on okuma until now?
    i think ... NO
    you need battery reset disk and Johnpool ask something, you answer correct to him?
  1. Servo problem after battery change
    By Andartur in forum Uncategorised MetalWorking Machines
    Last Post: 12-18-2023, 07:37 PM
  2. 2100 NCK ALARM 810D - NEED TO CHANGE BATTERY - WHERE IS THE BATTERY LOCATED?
    By scottbryce in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 09-22-2021, 07:35 AM
  3. CMOS Battery Low after RTC Change
    By blender in forum HURCO
    Last Post: 08-12-2014, 03:37 PM
  4. Battery change OSP7000L
    By bengt65 in forum Okuma
    Last Post: 06-17-2014, 03:31 PM
  5. Battery change resolved into problem
    By Andartur in forum Hyundai Kia
    Last Post: 05-20-2014, 06:57 AM
