585,917 active members*
3,481 visitors online*
    Sep 2017
    21
    Bed Mill Design And Fabrication Questions.
    Hello,
    I've been daydreaming about making a CNC bed mill out of steel. I have very little machining experience, so my questions may seem basic to most of you.
    Please take a look at the homemade bed mill in this post, and take note of the screws that I have circled. I'm guessing that the best way to drill these is with a mill, however in my design, the weight of the z axis plate may be too much for my knee mill (possibly). Is there another way to drill these holes perfectly? A magnetic drill, perhaps? Or should I just farm this out to a machine shop?
    I could also use precision angle plates (see attachment) on the inside of the z axis, but I would still run into the issue of drilling perfectly perpendicular holes.
    Part of the reason my Z plate will be so heavy is that I plan on using my existing knee mill's head on the new bed mill. It's got a 5hp motor and looks like it weighs at least 300lbs. I plan on using a design similar to Southwestern Trak bed mill's (except no cast iron, only steel).
    I would also like to avoid welding (with the exception of a few tacks here and there), as I don't want to transport this machine to get it stress relieved.
    Thank you in advance for your help.
    May 2013
    149
    Re: Bed Mill Design And Fabrication Questions.
    My advice would be not to kill the goose that lays the golden, if you get my drift.
    Buy a benchtop mill to convert to cnc and save the big knee mill for horsepower cuts on steel blocks, etc.
    Wisdom results from foolishness!
  1. Mill column design questions
    By gbrose85 in forum Mechanical Calculations/Engineering Design
    Last Post: 05-22-2020, 06:43 AM
  2. Small inline cnc mill frame design questions
    By Roadsidejobshop in forum Benchtop Machines
    Last Post: 08-20-2016, 02:34 AM
  3. Inventables Unveils Easel for Cloud-Based Design & Fabrication
    By cncadmin in forum News Announcements
    Last Post: 03-26-2014, 10:40 AM
  4. Replies: 0
    Last Post: 04-02-2012, 12:04 AM
  5. Router Mill Design Questions
    By dfro in forum Mechanical Calculations/Engineering Design
    Last Post: 08-02-2005, 02:01 PM
