504,473 active members
3,116 visitors online
IndustryArena Forum > Community Club House > International / Regional Forums > Australia, New Zealand Club House > Before I put power to micro step driver I need to confirm what gnd and vcc are please
Results 1 to 9 of 9
    Jun 2013
    328
    Hey G'day guys,
    Before I put power to this microsstep driver its juts a TB660.
    Can I assume that by GND they mean the minus and not actually earth?
    VCC is the positive?
    So from power supply I would minus to GND and Plus to VCC?
    Am I on the right path?
    Would prefer a none smoking smoldering path.
    Cheers and thanks in advance..
    Steve
    Aug 2005
    875
    Re: Before I put power to micro step driver I need to confirm what gnd and vcc are pl
    Hi Steve,
    Yes that sounds correct. GND is used quite often to identify the negative side of the power supply (-ve) rather than Earth.
    Cheers
    Peter
    Sent from my iPhone using Tapatalk Pro
    Homann Designs - http://www.homanndesigns.com/store
    Aug 2005
    875
    Also VCC is the power supply positive (+ve)
    Cheers
    Peter
    Jun 2013
    328
    Hey Peter G'day,
    Thank you for clearing that up for me much appreciated.
    I can proceed then without melting anything.
    Cheers and avagreatday,
    Steve
    Jun 2013
    328
    One other question please...
    I'm putting together my axbb-e I've never used a stepper controller before is why I'm asking.
    In the axbb manual I see step+ step- Dir+ Dir- the TB660 has ENA + ENA - (I'm assuming they are not used. Then DIR+ DIR- and PUL + PUL - I am assuming the PUL is the equivalent to the step as per axbb diagram? All the STEP and DIR - are wired to the 5V0.
    cheers and ty in advance.
    Steve
    Aug 2005
    875
    Hi Steve,
    Usually 5V0 means 5.0Volts. But, on the Axbb-e it is the 0V for the 5V output. So yes you are correct. The STEP- and DIR- should be connected to the 5V0 terminal.
    Cheers
    Peter.
    Jun 2013
    328
    Quote Originally Posted by phomann View Post
    Hi Steve,
    Cheers
    Peter.
    Peter ty again - I take it the pull +/- on the microstepper is the Step +/- on the axbb diagram?
    Cheers
    Steve
    Aug 2005
    875
    Yes, that’s correct.
    Peter
    Jun 2013
    328
    Cheers,
    Thought that may be the case..
    Regards,
    Steve
  1. Troubleshooting high pitch noise DM1182 Step Driver + 86HS45 Step motor
    By dtennes in forum General Off Topic Discussions
    Last Post: 01-20-2016, 09:08 PM
  2. My 20A bipolar micro-step driver design
    By nerginer in forum Stepper Motors / Drives
    Last Post: 08-29-2010, 07:33 PM
  3. help me confirm the power aspects of my controller
    By Dan Craig in forum General CNC Machine Related Electronics
    Last Post: 04-20-2009, 11:43 PM
  4. Full step and half step hybrid driver?
    By rkremser in forum Stepper Motors / Drives
    Last Post: 11-20-2008, 05:22 PM
  5. Step Motor Driver and Power Supply Wiring
    By mcan in forum Open Source Controller Boards
    Last Post: 01-19-2007, 11:22 AM
