549,843 active members*
2,894 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > best design for anti backlash rotary stage?
    Dec 2003
    144
    Considering several ideas for my 4th axis large scale foam carving build.
    I've got a few planetary gearheads laying around the shop so that would make a fourth axis easy.
    As the machine is quite large (requirements being able to machine a 4x4x4 cube} I'm worried about backlash on the rotary axis.
    gear drive? belt ? other ideas?
    Is a sentance fragment?
    Mar 2015
    168
    Re: best design for anti backlash rotary stage?
    Strain wave gear drive is what I would suggest. They are fairly expensive but you can find used ones on eBay etc. for reasonable cost. I believe Harmonic is one of the major brand names.
    Dec 2003
    144
    Quote Originally Posted by Paul-JB View Post
    This is what I really need. Checking Ebay to see if I can find something useful.
    Now that I know what to look for I might be able to source one from one of the local scrapyards.
  1. NEW DESIGN For Anti-Backlash Acme Nuts!
    By widgitmaster in forum Polls
    Last Post: 01-01-2016, 12:24 AM
  2. Anti-backlash rotary joint existance
    By TomB in forum Linear and Rotary Motion
    Last Post: 09-11-2012, 03:53 AM
  3. DIY Anti Backlash Design
    By PurduePete in forum Open Source CNC Machine Designs
    Last Post: 07-26-2012, 08:42 PM
  4. Anti-backlash nut design
    By lawrencex2 in forum Linear and Rotary Motion
    Last Post: 05-23-2012, 02:00 AM
  5. Anti backlash nut design
    By nakchak in forum DIY CNC Router Table Machines
    Last Post: 09-06-2008, 11:32 AM
