584,866 active members*
5,228 visitors online*
    Apr 2003
    178
    Beta 7 Available
    MeshCAM Beta 7 is now avaliable. You can download it at http://www.robgrz.com . Below is a list of changes included in this release. Please keep the suggestions and requests coming and I'll do what I can to satisfy them. If you've completed any work using MeshCAM then I'd love to see a picture and, with your permission, add it to a "User Projects" section of my website.
    - Added options to enable Coolant and Spindle M codes.
    - Fixed bug in Display Quality dialog.
    - Added "Show Bitmap While Dragging" option.
    - Removed the command entry window. Nobody liked it but me.
    - Change ASCII STL import filter to allow the exclusion of a solid name.
    - Save and load preferences on program start and end.
    - Added preference to remember open and save directory paths.
    - Added "Keep Proportional" option to open bitmap dialog.
    - Added a "Rotate Geometry" command.
    - Added a "Translate Geometry" command.
    - Gcode preamble and epilogue are now saved between program runs.
    - Added a "Geometry Properties" dialog to view the geometry position and size. Find it under "View->Geometry Properties."
    Thanks,
    Robert
    Apr 2003
    1876
    Sounds like some good upgrades. They were quick, too! I'll check it out shortly. Thanks!
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Jun 2003
    70
    Smile
    Keep up the good work Rob, I like where this is going.
    Jim Short
    www.tahlinc.com
  1. NC Plot v2 Beta 5
    By MetLHead in forum NCPlot G-Code editor / backplotter
    Last Post: 09-14-2008, 10:20 PM
  2. RoutOut CNC Software Beta
    By mikegaylor in forum News Announcements
    Last Post: 06-02-2006, 11:46 PM
  3. NCPlot v2 Beta 7
    Last Post: 06-09-2005, 11:41 PM
  4. NCPlot v2 Beta 6
    Last Post: 05-18-2005, 01:19 AM
  5. MeshCAM beta 8
    By robgrz in forum Uncategorised CAM Discussion
    Last Post: 11-23-2003, 04:05 AM
