589,272 active members*
6,657 visitors online*
Results 1 to 4 of 4
    Mar 2017
    1345
    Beta version 2024-06-06
    Is available here:
    https://planet-cnc.com/download.html
    Most important changes:
    - All input and output pins now begin with 1. First pin has index one.
    In previous versions some expression/python/API functions use 0 for first pin. Because this was inconsistent I decided to make this change.
    - Some parameters, that have "_num" at the end have this "_num" removed. For example "_input_num" was renamed to "_input". User manual is updated and all parameter names should be correct: https://cnc.zone/tng/parameters/parameters
    Parameters from "Coordinate System Table", "Tool Table" and "PointList" group still have "_num" suffix. This is also planned to change
    - Parameters now support string values and some old "$<...>" type values were removed. Most of them are related to tool names.
    There were also other changes, mostly bug fixes, API was consolidated and documentation was updated.
    I suggest you try this beta to check if your scripts need fixing. If you need help just send me .zip with your profile and I'll fix it. for you
    Aug 2023
    6
    Re: Beta version 2024-06-06
    I am using 2024_05_17 there ist no error or something if you start a script with _input_num| it just runs through the whole script just ignoring this parts. thats a high risk for damaged parts in ATC etc.
    Please avoid this massive changes to old parameters or print any kind of error when starting scripts with deleted unknown parameters.
    Are there any massive changes from 05_17 version to this one? Or just general stabilty and bug fixes?
    Mar 2017
    1345
    Generating error is good idea. I'll implement it.
    There are no major changes from 05-17 to 06-06.
    Mar 2017
    1345
    Working on this page:
    https://cnc.zone/tng/change_log
  1. Bug in version 2024.01.02
    By R2D3 in forum PlanetCNC
    Last Post: 02-18-2024, 11:10 AM
  2. EZ-CAM Version 2024
    By Master_CNC in forum EZ-CAM Solutions
    Last Post: 01-02-2024, 04:00 PM
  3. 2024 Aluminum
    By millford_turnny in forum Uncategorised MetalWorking Machines
    Last Post: 07-09-2012, 05:49 PM
  4. Control Interface version 1.422 Beta
    By jmb in forum Techno CNC
    Last Post: 03-22-2012, 08:57 AM
  5. 2024 T3 plate
    By rwild in forum MetalWork Discussion
    Last Post: 11-13-2009, 07:06 PM
