555,191 active members*
2,045 visitors online*
Results 1 to 4 of 4
    Apr 2004
    320
    Better guide rail dust covers
    I've been a little unhappy with the plastic guide rail dust covers that come with the Avid pro machines. The problem is that my shop is an unconditioned steel building, so it suffers from temperature extremes of 20s in the winter to 115 in the summer (with 40 degree daily swings). Those plastic covers tend to expand and warp up in between the hold down bolts. Picture below. So I decided to get some 1/4" aluminum stock and machine ( on the CNC... "machines building machines!") them as replacements.
    I modeled them in Fusion 360 and made recessed bolt holes similar to the plastic covers. Of course, I also need to cut a dado on the underside at 3/4" by 1/8" to allow clearance for the guide blocks. At first I tried doing this on the table saw (both vertically with an aluminum blade, then flat with a dado blade), but holding them down consistently proved to be a problem (not to mention that it generated aluminum flakes that I'll be cleaning up for a month....).
    So I finally ended up just putting it back on the CNC and machining the dado 1mm x 1.5mm on each pass. (Sorry, forgot to pictures of that).
    Below are all the pictures and final results, very happy with it!
    Bits used:
    Amana tool: #561776 - 1/4 O-flute aluminum
    Accupro: #43027382 - 1/4 x 2 x 4 3 flute aluminum
    Attachment 479810
    Attachment 479812
    Attachment 479814
    Attachment 479816
    Attachment 479818
    Attachment 479820
    Attachment 479822
    Dec 2020
    43
    Re: Better guide rail dust covers
    Well done!
    did you think about use this type cover ?
    Apr 2004
    320
    Quote Originally Posted by allencncrouter View Post
    Not even. Keeping it simple like the original design.
  1. V-Rail vs Linear Guide Rail
    By dbcheek in forum Avid CNC
    Last Post: 03-06-2019, 10:42 PM
  2. Linear guide rail question
    By janz99 in forum Linear and Rotary Motion
    Last Post: 06-21-2015, 04:37 AM
  3. DIY Rail Covers or Just Going NAKED!
    By Plugger in forum Uncategorised MetalWorking Machines
    Last Post: 05-20-2011, 09:26 PM
  4. Questions on rail covers, dual servo hunting,and rail preload
    Last Post: 05-14-2011, 05:00 AM
  5. Dust covers (boots)
    By Kev in forum DIY CNC Router Table Machines
    Last Post: 03-30-2004, 01:21 AM
