586,961 active members*
2,694 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Biesse > Biesse Rover27 Communication with Device errors
    Apr 2024
    Exclamation Biesse Rover27 Communication with Device errors
    Hi, I'm running Biesse's Rover 27 with XNC. I was running patterns just fine until it started requesting a slot reset after I press the stop and reset buttons to clear or swap a program, and would claim I performed a manual tool change when I didn't. It would not respond after clearing a program with the stop and reset buttons, so I would have to restart the system which would fix the issue until I finished a program and it thought I was doing a manual tool change. This issue evolved into now not allowing the cnc to connect internally and throwing different errors at random in 2 instances. One instance when I boot up the computer the XNC loads but throws an irreversible halt and claims there's no non-volatile memory available. The second instance tells me I/O module missing and IOS cards 0-7 are missing. Ive checked the CMOS and it's fine as I've heard that's an issue with the non-volatile memory. Any one have any ideas what I could try to start troubleshooting further?
    Apr 2024
    Re: Biesse Rover27 Communication with Device errors
    Additional errors that have popped up.
    PLC 390 > No non-volatile memory available. (NVRAM)
    PLC 375 > Time-out during communication with a device (ax.0.0.0)
    PLC 387 > Irreversible HALT
    ; System boots with either one set of errors or the other. seemingly no indication of what causes which ones to appear, randomly selects a set and displays them, original thread errors included.
    Yas 626 > E6: MECHATROLINK communications error (Axis X)
    Yas 626 > E6: MECHATROLINK communications error (Axis Y)
    Yas 626 > E6: MECHATROLINK communications error (Axis Z)
    Yas 626 > E6: MECHATROLINK communications error (Axis Cr1)
  1. errors biesse B765
    By mamoulas in forum Biesse
    Last Post: 03-22-2022, 11:44 AM
  2. biesse errors
    By mo88as in forum Biesse
    Last Post: 02-19-2020, 04:25 PM
  3. YASNAC MX-3 communication errors
    By L98FIERO in forum Controller & Computer Solutions
    Last Post: 07-23-2019, 01:33 PM
  4. Communication errors
    By Smokio in forum Fadal
    Last Post: 10-07-2012, 12:56 AM
