525,618 active members*
2,456 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Black Screen Mother board
Results 1 to 12 of 12
    Junior Member
    Sep 2008
    92
    Does anyone know the source of this problem? The fault was presented after I replaced the CMOS battery of the motherboard 3-424-2283A01 ... I can enter the Bios and the hard drive is detected ... When the blue screen should appear before starting the windows shows The black screen and nothing happens ... I Install the HDD on another machine and it works perfectly
    any ideas?
    Jun 2005
    1381
    Re: Black Screen Mother board
    Check the bios and determine the boot device. It can be USB , floppy, hard disk, cd/DVD and you can order them, make sure the hard disk is listed first, you probably lost this setting when the cmos battery died
    Russ
    Junior Member
    Sep 2008
    92
    I was already reviewing the Bios, but I'm not sure I configured it well, I've made several attempts without any success
    Jun 2005
    1381
    See if you can do a screenshot of your bios page, if when you change the bios make sure you click the button to save your settings. If the hard drive boots on another system the boot sector must be there. Normally you can't take a Windows hard disk from one computer and get it to boot correctly on another motherboard due to their licensing restrictions but it should try and start up.
    Russ
    Dec 2006
    513
    Which board are you referring to as a mother board?? Is it on the far right or on the far left board???
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Junior Member
    Sep 2008
    92
    Im referring on the far left board, Now Im sure the Bios setting is right, but the black screen still
    Aug 2015
    98
    Attached is a BIOS settings PDF. Not sure if these settings match your motherboard or not?
    Junior Member
    Sep 2008
    92
    I configured the Bios based on the information I attached but the black screen persists
    Attachment 371742
    Aug 2015
    98
    Is all your cabeling plugged into the right spot in the motherboard? Or is it all plugged in in General. Wondering if the HDD isnt plugged in or something?
    Dec 2006
    513
    What is the board part# on your work station board ( far left ). We need that number to give you the correct BIOS settings
    Jun 2020
    Quote Originally Posted by megaman26 View Post
    any ideas?
    Did you ever resolve this issue?
    I've been looking for the 2283A01 CMOS. it appears that Cincinnati won't support these any longer
    Mar 2011
    339
    There were a couple different BIOS used for that board number. Send me a PM with the board number and BIOS version and I should be able to get you the proper config for it.
  1. The CNC Mother Board
    By avayan in forum Open Source Controller Boards
    Last Post: 11-30-2012, 10:59 PM
  2. The CNC Mother Board
    By avayan in forum Stepper Motors / Drives
    Last Post: 10-04-2012, 12:37 PM
  3. DX-32 Mother Board
    By minton in forum Bridgeport / Hardinge Mills
    Last Post: 09-22-2011, 04:35 AM
  4. CNC Mill- Needs Mother Board
    By Jim77 in forum Want To Buy...Need help!
    Last Post: 02-03-2011, 04:33 PM
  5. Mother board help
    By Stu D in forum Servo Motors / Drives
    Last Post: 07-28-2006, 02:48 PM
