545,577 active members*
7,079 visitors online*
    Aug 2014
    102
    BLDC controller with PWM input
    I have a Novakon nm135 with stock BLDC controller and spindle motor. I have no manual but found similar controllers that say:
    PWM--control input-pin 500-5KHz of the PWM control signal 10% -90% of the minimum speed can be controlled to the highest (Recommended frequency: 1KHz)
    I don't know a lot about electronics but I think servo pwm is 500hz? It also looks like 1hkz is the recommended frequency? So 0-1000hz? I purchased a mach3 breakout that says it's capable of 2.5khz. Also has a d/a pwm 0-10v.
    On the controller I see:
    12v
    5v
    NC
    Stop (stop/start)
    F/R (I assume forward reverse)
    PWM
    GND
    I assume the last two are all I need to get the motor spinning at variables speeds but I could be wrong. There is also another 2 pin connector labeled PC1 & PC2 which I have included a photo of. It came wired with a jumper but maybe this could be an alternative 0-10v control?
    I have included the breakout board I have coming. It looks like P1 is the pwm output but it also can do 0-10v.
    Sent from my BE2025 using Tapatalk
    Jan 2018
    800
    Re: BLDC controller with PWM input
    Quote Originally Posted by hax0red View Post
    PWM and Analog 0-10v are 2 different things.
    You connect a small PWM to Analog 0-10v converter board to use a PWM signal to the Analog of a drive.
    Something like:
    https://www.aliexpress.com/item/32834921874.html
    The PC1/PC2 is most likely a power related item.
    Aug 2014
    102
    Quote Originally Posted by dazp1976 View Post
    Something like:
    Yeah I know they are different, I was saying PC1/2 might be 0-10v analog.
    It's my understanding that the board I purchased has both PWM support and 0-10v and there are PWM pins on the controller so I wouldn't need any converter if these match up.
    I'm just not sure how to get it working with mach3 but it sounds like I'll have to figure it out.
    Sent from my SM-T860 using Tapatalk
  1. Replies: 0
    Last Post: 01-11-2021, 06:02 PM
  2. BLDC controller troubleshooting
    By moto52000 in forum Benchtop Machines
    Last Post: 11-07-2019, 03:27 AM
  3. BLDC Motor needs a new Controller
    By maxspongebob in forum Spindles / VFD
    Last Post: 11-05-2019, 10:00 PM
  4. Searching for a BLDC or AC servo Controller
    By irxplod in forum Open Source Controller Boards
    Last Post: 05-13-2011, 09:27 PM
  5. brushed servo drive with PWM & direction input
    By visky in forum Open Source Controller Boards
    Last Post: 06-17-2009, 07:14 PM
