525,666 active members*
2,242 visitors online*
Results 1 to 5 of 5
    Feb 2009
    7
    Bluecarve ballscrew design
    What is your opinion on this ballscrew design being sold as a hobby machine , no support or thrust control on any axis ?
    Dec 2013
    4378
    Re: Bluecarve ballscrew design
    Most likely not very robust. The motor is not really designed for axial thrust load.
    Jim Dawson
    Sandy, Oregon, USA
    Gold Member
    Apr 2004
    5052
    Like Jim says. The ball screw will have a lot of play in it along its long axis; cutting forces will be able to push it around, so expect poor cut quality and forget about precision. But it's a lot cheaper to do it that way than to have to provide all those bearings and such.
    Andrew Werby
    Website
    Feb 2009
    7
    It seems to have the same setup on every axis including the Z
    Nov 2012
    891
    It works good enough to sell the machine. After a while it stops working, then you need to replace the broken motor and redesign the ballscrew mount.
  1. Ballscrew design and 12vdc rpm and torque calculations Help Required
    By RSutton in forum Mechanical Calculations/Engineering Design
    Last Post: 09-02-2019, 05:33 AM
  2. Bridgeport ballscrew retrofit, design the yoke
    By daroc30 in forum Bridgeport / Hardinge Mills
    Last Post: 03-25-2019, 11:40 AM
  3. Design Feedback For 8020 Ballscrew and Linear Rail Design
    By GisMo in forum DIY CNC Router Table Machines
    Last Post: 02-01-2018, 01:30 PM
  4. Design question regarding ballscrew and bearings
    By taskman in forum Mechanical Calculations/Engineering Design
    Last Post: 12-13-2013, 05:20 AM
  5. Super simple preloaded ballscrew design - It Works!
    By jimjovan in forum Vertical Mill, Lathe Project Log
    Last Post: 04-25-2005, 05:02 PM
