600,786 active members*
2,957 visitors online*
Results 1 to 8 of 8
    Sep 2007
    300
    Boss Y axis support bearing size?
    I have about 2 thou backlash in my Y axis, coming from the ballscrew support bearings. I hate to tear it apart to see what size they are so I can order some. Does anyone have the bearing number (not BP part number) ?
    Its a boss 3 with the large cnc type table and I don't believe they changed bearing sizes over the years for that table type.
    Thanks !
    George
    Jan 2005
    15362
    Re: Boss Y axis support bearing size?
    Quote Originally Posted by Sparky_NY View Post
    Thanks !
    George
    I don't have the size, but there are 2 precision AC Bearing mounted Back to Back, ( if they are not to worn to bad, you could adjust them with a shim or by Grinding ) Something to try, there is a preload ring behind the timing pulley, that has 4 SHCS you could try to tighten these 4 cap-screws to see if that helps
    Mactec54
    Sep 2007
    300
    I have seen that setup before in other bridgeports. I would like to find the bearing number so I can have them onhand when I go in there. Its old enough that it would be no surprise the bearings would be bad.
    Jan 2005
    15362
    I have a new Ballscrew, so I can measure the ID diameter so it is 25x52 x15 for the Bearing here is a link to some they come from many different manufacturers
    BSB2025DUHP3 - Precision Angular Contact - 25x52x15
    Mactec54
    Sep 2007
    300
    I have a new Ballscrew, so I cam measure the ID diameter so it is 25x52 x15 for the Bearing here is a link to some they come from many different manufacturers
    Thanks much ! Its bigger than I expected. I found a online forum thread where it was said the BP boss Y axis was a 7204 size, which is only 20x47. The X bearing are much much larger being a rotating nut type.
    Jan 2005
    15362
    The 20x47 is what the manual machines have for the Hiwin Ballscrew Kits
    Yes the X axes is a 50x80x16
    Mactec54
    Sep 2007
    300
    Very much appreciate the info Martec ! Thanks again.
    Mar 2025
    If the dimensions are 20X47, you might try searching for this part number: 20TAC47C, the dimensions are 20X47X15
  1. Z axis linear bearing rail size 9mm or larger ?
    By Docop in forum Linear and Rotary Motion
    Last Post: 03-19-2016, 05:46 PM
  2. Replies: 3
    Last Post: 02-28-2012, 11:03 AM
  3. what size servo motor for axis movement BOSS 4
    By JDP3 in forum Servo Motors / Drives
    Last Post: 11-06-2009, 06:31 PM
  4. X-Y-Z Axis Bearing Support - Dimensions?
    By joecomunale in forum Joes CNC Model 2006
    Last Post: 05-17-2007, 11:49 PM
