567,674 active members*
2,927 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Both vacuum pumps tripping breakers after 15 seconds of running
Results 1 to 16 of 16
    I am installing a new StyleCNC 1325-R1 and both of my vacuum pumps are tripping their control cabinet breakers after running about 15 seconds. It is a 220v single phase system. I have tried switching the 220wires to no avail. When the breaker trips there is an E25 code displaying in the internal breaker. The same code appears on each of the two vacuum pump breakers. Help please.
    Community Moderator Al_The_Man's Avatar
    Dec 2003
    24150
    Re: Both vacuum pumps tripping breakers after 15 seconds of running
    What is the model of the Vacuum pumps?
    Also are you running them wide open? i.e. No pipe duct etc?
    Test by partly throttling the input.
    Albert E.
    Neuer Benutzer
    Jan 2013
    425
    Quote Originally Posted by finallygotauserid View Post
    Are the pumps correctly topped up with vac oil (if needed)? Check current draw with clamp meter set for amps too.
    Dec 2003
    24150
    So what's the verdict?
    Albert E.
    Jan 2005
    15331
    Check the Grounding on the machine, from each vacuum pump, it sounds like you have a wiring problem, or an overload problem.
    How many Amps is your 230v /240v single phase supply to the machine??
    What is the amp rating on the vacuum pump motors??
    Mactec54
    Dec 2003
    24150
    The occasions where I have been called in to this problem is that the user has both inlet and outlet, unconnected to any duct etc.
    Result, motor overload.
    Albert E.
    Neuer Benutzer
    Jan 2013
    425
    Quote Originally Posted by Al_The_Man View Post
    I've only ever used big vacuum pumps and they have vac oil to protect the vanes and assist vacuum pull down. But surely an open ended vac pump would run longer than 15 seconds before getting tight enough to cause an overload? Pulling a vacuum would cause greater motor load than free wheeling, for example on a Vaughan pump or similar.
    What pumps are you familiar with?
    I'm new to the site and I'm still trying to figure out how to find my posts ... sorry for not responding. I've figured out my problem. There are two fairly sophisticated breakers in the cabinet ... One for each vacuum pump. Each has the capability of setting the overload current detection value. I had to request the user manual from StyleCNC for the breakers before I could figure out what to do. The value for the "expected current" was set way too low. Therefore the breaker assumed a short circuit - E25. I raised the value about 50% wondering what would happen. I then got an E23 error - current overload. Quite helpful since it told me I was on the right path. I then raised the value another 50% and that solved the problem.
    Again, I apologize for not responding to the replies. I simply couldn't figure out how to view my posts, and replies. I still don't know how, but I'll eventually figure it out.
    Community Moderator RaderSidetrack's Avatar
    Apr 2018
    62
    You haven't told us what kind of device you are using (phone, maybe?). I have attached a screenshot from my Android phone:
    Attachment 489512
    The "User CP" in the header is the Control Panel, so click that. You should see a link to Subscribed Threads, which should normally include threads you have posted in.
    Quote Originally Posted by RaderSidetrack View Post
    Attachment 489512
    I'm using an android phone. But when I click User CP no posts appear ... not even the thread I posted the solution. Hmmm
    Apr 2018
    62
    There should be a LINK shown at User CP that is called Subscribed Threads. Click that.
    The forum software at CNCZone is a 10 year old version vBulletin 4, and that software wasn't built with 'phone' users in mind. So its outdated, and hard to use with a phone. I try to avoid using my phone for reading the Zone, and use a desktop or laptop when I can.
    There is a way on your phone to tell it to use the "desktop" version of a website (rather than the default "mobile" version that many sites feed you when they detect a mobile device at your end). With say Firefox on a phone, while at CNCZone, click the '3 dot' vertical menu button and choose "Desktop site". Other browsers have similar options but may word it differently. You may/may not like that version better, but its something you can try.
    There is an update to CNCZone forum software in the works ... but for now we make do with what is here.
    Dec 2022
    13
    We have a new STYLECNC machine at our shop and have had similar issues, what we found was that the wiring was poorly done and some were loose. We took apart our contactors and gave them a good cleaning with the air compressor since they were filled with dust/debris, then we reinstalled all the wiring to ensure full contact. Our problem was solved, not saying your machine has the same issue, it's worth a try.
    Jan 2005
    15331
    Quote Originally Posted by misterthi View Post
    I would say what you found would be the same as what some of their problem was also, and it most likely has not been corrected, most of these imported Routers need wiring checked as you did is a must, as they have poor Grounding and wiring practices in general, metal chips in contactor is common also.
    Mactec54
    I am having a StyleCNC being delivered in 2 weeks. If you have that breaker manual and can email it to me, it might save me some time if I have the same issue. I probably have the same vac pumps and breakers, but my machine will be the STM1530C. Thanks. If I can help after I get my machine setup, the more people connected should make it all easier. I have had a few people contact me and I am trying to find others with StyleCNC machines.
    Cleanairwoodworks@gmail.com
    Neuer Benutzer
    Jan 2013
    425
    You were advised to check current early doors by me and another poster.
    Dec 2022
    13
    for our vacuums, we upped the number on the unit to 22, it came set at 12 and would always turn off after a few seconds. We kept having to adjust slowly until it was stable.
  1. sl150y machine shutting down, tripping breakers
    By mikeminok in forum Mori Seiki lathes
    Last Post: 04-22-2021, 12:50 AM
  2. Avid CNC tripping breakers?
    By jamesfiore in forum Avid CNC
    Last Post: 11-24-2020, 04:43 PM
  3. vacuum tables and pumps
    By cabnet636 in forum Camaster
    Last Post: 08-24-2015, 12:29 AM
  4. Vacuum pumps off ebay
    By JanHenning in forum Work Fixtures / Hold-Down Solutions
    Last Post: 02-19-2009, 09:38 AM
