540,529 active members*
1,727 visitors online*
    May 2006
    20
    Bracket for Lid - Bodor
    I have a 90W Bodor laser. I ran into two situations that I needed to resolve. First was that the small notch in the front of the hood (lid) didn't allow for enough air flow to adequately allow the smoke to clear. Second was that the laser is not designed to have material sticking out the front of the laser. For the smoke, I usually just prop the lid up with a roll of tape but yesterday, I needed to have a longer piece of wood project out the front so that I could laser my woodworking logo in the corner of a project. I designed and 3D printed a bracket that hooks over the lip in the bottom of the opening and has a notch to hold the lid and not slip. Works great. Thought I'd share for those that need something similar. While designed for by Bodor, it could be modified to work with other lasers. I ended up using two (one on each side) so as not to rack the lid.
    Sep 2019
    Re: Bracket for Lid - Bodor
    Useful accessory for the desktop laser engraver, clever tool
  1. 6061 Bracket
    By BLKFLD in forum USA RFQ's
    Last Post: 07-09-2016, 11:03 PM
  2. GPS Bracket
    By Jigantor in forum General MetalWork Discussion
    Last Post: 05-22-2013, 12:01 AM
  3. RFQ - Steel bracket
    By bobmagnuson in forum RFQ (Request for Quote)
    Last Post: 08-04-2011, 02:25 AM
  4. RFQ: Holddown bracket
    By Enraged in forum Employment Opportunity
    Last Post: 01-19-2011, 05:36 PM
  5. 3D Corner Bracket
    By WizzBoy in forum Mechanical Calculations/Engineering Design
    Last Post: 08-02-2010, 03:01 AM
