578,964 active members*
7,904 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport 1J Motor 4 step-pulley dimensions required
    Jun 2005
    6
    I got a 1J head which did not have the motor.
    Now got a 2 speed 50Hz motor which does not have the belt pulley.
    Does anyone have the correct pulley or the dimensions of the 4 diameters.
    I wont be using any VFD or such.
    Thanks Ray
    Feb 2006
    162
    Re: Bridgeport 1J Motor 4 step-pulley dimensions required
    Ray , not sure of your specifications with the UK version of the bridgeport
    maybe this can help, My BP is a J head, 1962 model 4 step pulley
    Spindle Speeds are 660,1115,1750,2720 RPM
    Motor is a 220 Volt 3 Phase 1745 RPM
    Motor Pulleys are
    3.20-4.600-5.820-7,000 as best as I can measure
    I feel very confident with the 7.00" diameter and the spindle pulley is about 4.52 " at that diameter
    It is difficult to accurately measure without taking the head-stock and motor apart
    Good luck because if not right , it will be difficult to switch speeds and still tighten the belt.
    I have no manual , so no help there
    Rich
    Jun 2005
    6
    Thanks Rich,
    Your speeds are a bit faster (UK 2400rpm/4800rpm top speeds on 2 speed motor) Your mains is 60hz vs UK 50hz but I am not exactly sure about the US belt ratios. I appreciate your assistance and agree that each step pair will need to have the same belt length. 7.0 is a good starting point.
