601,127 active members*
2,386 visitors online*
Page 1 of 2 12
Results 1 to 20 of 31
    Oct 2006
    17
    Bridgeport Series 1 Heidenhain TNC 145
    I purchased a used CNC Mill - Bridgeport Series 1 Heidenhain TNC 145 control.
    This is my second cnc machine and I do not have much experience of operating CNC machines. The main purpose of this machine is to get hands on experience in milling cnc machining.
    I have traid o change the buffer battery and i have lost all the information does any one know how to program it ??
    I will appreciate the input of members about their experience and advice and also regarding the various CAM programs I should start exploring.
    you can send me the information
    to my mail ( [email protected] )
    Pestana1957
    Jan 2005
    1121
    re
    is it an interact or a r2c3?
    I have a parameter set that will run the r2c3 right out of the box. Probably the interact, but there might be small differences
    Oct 2006
    17
    its an Interact
    tanks any help will be good
    Jan 2005
    1121
    re
    I'll get the file together tomorrow when I am in the office
    One thing that I know is different is the homing direction in y
    If you down load the control tech manuals from heidenhain.com, you will have the parameter definitions
    Jan 2005
    1121
    re
    attached is a parameter list for a bridgeport heidenhain r2c3. parameters 33 and 34 are almost certainly wrong, and all axis travel parameters [31-36] are suspect. THIS WILL TRASH YOUR MACHINE.
    Get the manual and find out which is the direction when running over reference marks, as that differs on my r2c3 vs my interact.
    Once you can get it homed, you can slowly move it in every direction to see if it stops too early [visual x axis limit] or not soon enough[emo, flashing error]
    once you initially enter the parameters, you can edit them by being in metric mode, manual mode, type 95148, enter. delete block gets you out
    be careful
    Attached Files Attached Files
    Oct 2006
    17
    Hi Gus first of all tank you for you help,
    I have enter the parameters from 0 to 55 and then it gave me an erro
    massage (Program Memory Erased)I didn't get to enter the parameters to the end 78, but I have tried and it move´s well the Z axis,the X,Y axis
    thoes not move in one direction.tho you have any idea what this be
    Tanks
    Pestana1957
    Jan 2005
    1121
    re
    Maybe it is an old software rev that only has that many parameters?
    the x and y axis issue is the travel limit parameters I told you about
    I will try to get my interact parameters tomorrow, that computer died today
    Nov 2006
    925
    Pestana,if you give me an email address I will send you the manuals for the 145.
    Mark.
    Oct 2006
    17
    Hi Gridldley51
    tanks for you help
    tanks
    Pestana1957
    Jan 2005
    1121
    re
    interact 151 parameters, 2 different sets
    parameters 44 to 49 appear to be the relevant axis limit parameters
    the rest of the list IS NOT relevant to you machine
    BE FREAKIN CAREFUL [BOOM]
    Nov 2004
    3028
    I found a parameter list from 1983 and I believe it is a TNC145. With descriptions of what each parameter is.
    George
    Jan 2005
    1121
    re
    appears to be r2c3 rather than interact, so the descriptions would match the first set that I posted
    Oct 2006
    17
    Hi tanks avery one
    yes they are very similar I have been doing tests step by step line by
    line and this almost done!
    I only have a problem I can not make handwheel to work.
    tanks to all for the great help
    Pestana1957
    Jan 2005
    1121
    it only works in handwheel mode, the little button with the, errr handwheel symbol on it. there might be a parameter for handwheel present/absent
    Jan 2005
    1121
    handwheel
    doesn't appear to be a parameter, maybe you have the feed set very low. enter the number 2 while in handwheel mode, should move ok
    Oct 2006
    17
    Thanks Gus.
    I've already entered the number 2 and it still doesn't work. I decided to open the handwheel backcover and I've noticed that the glass disk has no black stripes on it. I think that it should look like an encoder disk, but its clean. I think that someone before me had already opened and cleaned it by mistake. Or can it just disappear? Gus, have you already opened one? Do you have any idea of how it should look like in the inside? If you do, do have any clue about how the black stripes should look like?
    Any help will be good.
    Thanks,
    Pestana1957
  17. #17
    Oct 2006
    17
    Hi Gus.
    Do you have any example or any sample program for the Bridgeport Series 1 Heidenhain TNC 145 that I can explore and to help me see how it works.
    Thanks,
    Pestana1957
  18. #18
    Jan 2005
    1121
    re
    here is one, drilliing some holes and a small milling pass
  19. #19
    Jun 2009
    5
    hello some some body can helpme I need the parameters for the bridgeport series 1 INTERACT milling machine that uses HEIDENHAIN TNC 145 contouring control.thank you
  20. #20
    Nov 2004
    3028
    Look up above. There are 2 versions. One with 72 parameters, one with 78. It depends on the version of software inside the control. The PC and NC numbers.
    Some parameters are machine specific, such as backlash and travel from the home switches.
    George
Page 1 of 2 12
  1. Bridgeport Series 2 Interact 2 Heidenhain TNC 155
    By rrossey in forum Bridgeport / Hardinge Mills
    Last Post: 11-30-2023, 01:10 AM
  2. Bridgeport Series II Interact 4 / Heidenhain Book
    By wme123 in forum Bridgeport / Hardinge Mills
    Last Post: 06-02-2014, 02:05 PM
  3. BRIDGEPORT INTERACT 2 SERIES 2 WITH HEIDENHAIN TNC 145
    By tommo61 in forum Bridgeport / Hardinge Mills
    Last Post: 05-16-2013, 12:09 PM
  4. Bridgeport series 1 MDI Heidenhain TNC 131
    By drumsticksplint in forum Bridgeport / Hardinge Mills
    Last Post: 04-09-2013, 07:24 PM
  5. Bridgeport Series 1 Heidenhain 2500
    By exhausted in forum Bridgeport / Hardinge Mills
    Last Post: 09-30-2010, 06:58 PM
