535,633 active members*
3,729 visitors online*
Results 1 to 16 of 16
    Mar 2003
    12
    Bridgeport VMC 760 - 22
    Hey all!
    I've got a VMC 760 heading my way and is in the need for some info on how to get it off the truck and moving it around.
    If anyone has a copy of the machine manual with the pre-/installation guide would be great and much appreciated, i've tried googling and searching this forum for all weekend without any finds...
    All the pictures i can find on the machine the chip / coolant tray is in the way of the machine base so i don't really know to move this thing in to its position. Biggest problem being the garage door it needs to come through, it's big enough to get the machine in if the short sides go in first but i guess i need a really big forklift for this that might not go though the door. Also there is a small track/ridge the door runs on, so my idea of putting the machine on steel plates with rollers on wont be possibly through the door.
    Would it be possible to get some pictures of the machine base from anyone operating this machine?
    Any guidance would be highly appreciated!!
    Many thanks in advance
    Patrik
    Feb 2005
    69
    Re: Bridgeport VMC 760 - 22
    I tried to private message you but you have it blocked to not receive messages. I can email you a copy of the manual.
    Feb 2005
    69
    You lift it from the right side of the machine. There are fork pockets in the base and you will need 80 inch long forks. Hope this helps.
    Oct 2010
    1189
    Patrick if still needed i can do pictures of that machine for you this week ,.. And the Factory maybe has a Manual to Check ,..
    Gesendet von iPad mit Tapatalk
    Mar 2003
    12
    Just tried sending factory guy a PM. Let's see where that takes us but thanks for the offer thamsker!
    Feb 2005
    69
    I sent you an email 2 days ago, did you get the manual?
    Mar 2003
    12
    Sorry Yes!!! THANK you so much!!! Very appreciated
    I guess the base of the machine is the same between the American vs European/English made one?
    Feb 2005
    69
    I can't answer that but I would think it would be. Glad I could help.
    Oct 2010
    1189
    Question i might retrofit it which servos dös the machine use ? Is thst in the Manual ? And min max nm ,..
    Mar 2003
    12
    Tried to send you a PM but told me your inbox was full.
    The manual i got specify X & Y at 6,5 Nm and Z at 14 Nm
    Patrik
    Oct 2010
    1189
    thx
    therefore your mailbox says you don't like pm mails -
    question is 6,5 and 14 the max or stall force ?
    thx
    thomas
    Mar 2003
    12
    Thamsker did you get my PM?
    Oct 2010
    1189
    Sorry i was verry busy no i didnt get it ...
    Mar 2003
    12
    Hi all, quick update.
    Once again thanks for all the help.
    Machine arrived yesterday and even though we specifically asked for the machine to be placed in the truck so we could unload the machine from the rear of the truck using the forklift pockets in the base of the machine, it didn't. Honestly i don't even know how they loaded it cause in now way we could just "fork in -n- lift" which made the unloading bit difficult and took some time. But she is finally in!
    Here is some pictures of the unloading
    Quote Originally Posted by Factory Guy View Post
    Hello is it possible to have a copy of that manual too? thank you!
    controlcars@yahoo,com
    Jan 2021
    4
    I need a manual too!
    760/22 #076
    At least the wiring schematic
    Ddrpm.llc@gmail.com
  1. BRIDGEPORT EXPLORER X26 BRIDGEPORT DX-32 CONTROL Installation
    By rojaselectri in forum Bridgeport / Hardinge Mills
    Last Post: 12-22-2013, 07:46 PM
  2. Bridgeport R2E3 with VFD. Bridgeport gear, speed and direction settings.
    By ronderkis in forum Bridgeport / Hardinge Mills
    Last Post: 04-23-2013, 10:50 AM
  3. Bridgeport
    By morgandc in forum Bridgeport / Hardinge Mills
    Last Post: 12-16-2011, 01:53 PM
  4. Bridgeport DNC
    By hmc710 in forum Bridgeport / Hardinge Mills
    Last Post: 02-09-2010, 01:14 AM
  5. Bridgeport VMC 760 22
    By mak0 in forum General CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-11-2008, 12:22 AM
