Hello everyone!
First off, thrilled to be part of the network - I am new here but have read some of the posts on the arena during my search for a good machine and appreciate the level of professional advice others have found here.
As for the said search - I am looking for a laser engraver to do specifically vector drawing engravings and cuts on 1/8" acrylic. Possibly wood cuts/engravings as well, but acrylic jobs mainly. So far I have been using a Versalaser VLS3.50 with a 30W Synrad tube afterhours at work, and it's been absolutely great, but I need my own machine to avoid conflict of interest.
So, to be more specific what I'm looking for is:
- an Air-cooled RF laser tube of at least 30W (not DC as it does not engrave as fast or as well as RF due to power fluctuations and beam size)
- 12x24" minimum bed size.
- Ideally a tabletop machine, since my shop is on the 2nd floor and from my experience even the smallest lasers are obscenely heavy to lift. Something between 50-70kg (120-140lbs) would be perfect.
- has to be under $5000. that is the absolute total budget I have to work with.
So far I've discovered that the used laser cutter landscape in my area is scarce. I found a few listings, some turned out to be scams, others were just sold very quickly. After the smoke cleared I found myself having a conversation with two ebay sellers both within a couple of hours drive from me - one has a 2003 Epilog Legend 24EX with about 3000 hours on the tube going for $4500. The other - a Gravograph LS900 that needs the honeycomb table replaced, going for $2800. The trouble with either of these is they are both over 300lbs and dimensionally may not fit up the narrow staircase in my shop. But who knows, I can get creative..
So, if anyone here has any experience with either of these two machines, please chime in. Are there any glaring issues with any of these models that you know of? Do either of them come apart into smaller bits that can be safely carried by 3-4 men up a 3' stair and then reassembled? What about running the machines themselves? I believe epilogs in general are pretty bulletproof, but the Gravograph is a wildcard - I heard they're built like tanks, however the tech support leaves a lot to be desired.
And lastly, if there are other machines you think you can recommend that would be close to my specs - please let me know. I am all ears.
Big thanks in advance!
0l0id
