525,364 active members*
2,499 visitors online*
    Bystronic laser
    Hello,
    I work on Bystronic laser Bystar 4020.
    We have some problems working on it.
    When we run some programs on the,for example,thickness 5 mm it works very well.
    When we want to run another programs on the same conditions programs cutting plan can be seen on the laser.Program starts.Cutting head only make first piercing and nothing else.t makes piecing untill we press stop.It can not make any circle.Where is the problem? Thanks in advance
    Re: Bystronic laser
    I might be able to help. Send me a message. Thanks
    Jul 2020
    7
    Re: Bystronic laser
    I can help you to retrofit your machine with fiber laser. send me email.
    lirenzhi@newlas.com
  1. I have a problem with bystronic laser
    By ajwan in forum Uncategorised MetalWorking Machines
    Last Post: 02-03-2019, 01:03 PM
  2. Bystronic 5" Laser cutting head
    By centreville in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 12-05-2018, 10:20 PM
  3. Bystronic bystar laser 2800kw
    By patrickas in forum Laser Control Software
    Last Post: 09-21-2018, 08:17 PM
  4. Program stop on Bystronic laser
    By jdr1961 in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 06-11-2012, 02:20 AM
  5. Bystronic Laser
    By wda in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 02-28-2012, 01:40 PM
