578,966 active members*
7,731 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Cadet 700l chuck clamp sensor shorts when activate
    Sep 2022
    Chuck clamp proximity switch shorts every time activated, shutting down control panel.
    checked all wires for short from prox switch to conversion board.
    tried different ports of ph1 distribution block, putting wire from port to xb-hs-1-b3
    conversion board connector.
    changed fub p4m4 and conversion board, swapped switches, new cables all with same result,
    SHORT
    what am I missing?
    Re: Cadet 700l chuck clamp sensor shorts when activate
    Quote Originally Posted by CAMBIRD970 View Post
    SHORT
    what am I missing?
    Could it be the chuck clamp proximity switch short itself?
    Try to replace a new chuck clamp proximity switch and see what happens.
    Sep 2022
    Forgot to mention I switched cables to sensors and same result,
    always on clamp side. put clamp parameter from O.D. to I.D.
    that changes clamp sensor to unclamp, unclamp sensor to clamp.
    the short happens when unclamped now.
    short always stays with same wire going to conversion board connector.
    Mar 2009
    1939
    Quite chaotic diagnostic. Once again, if rewiring to another LS the fault moves with? So the inductive LS itself is faulty.
    If fault stays at the same place regarding conversion board, check the input of the conversion board. Should be resistor there. Check it.
