547,569 active members*
2,383 visitors online*
    Cam style program
    Good day everyone,
    I'm just setting up a used 50W desktop laser cutter. I am looking for a CAM style program that will run a laser and allow a tool offset as is done in the milling CAM software such as mecsoft. This will allow me to draw one file and allow me to run it in a CNC router, 3D printer or the Laser without having to do a second drawing with the lines offset to compensate for the kerf of the laser. Does anyone know of such a program? I am willing to spend several hundred dollars so the professional grade $10,000 per year such as Esprite are out of the question.
    Thanks for you input.
    Mar 2014
    43
    Re: Cam style program
    You can use Fusion 360 to create the files and offset the toolpath, you will only need (to build) a postprocessor for your control
    Jun 2015
    3397
    hy, pls share a few drawings, so to have an idea about complexity; i can deliver custom applications / kindly
  1. program of tab program in mori sv 400 and program tool chance
    By hmtam1311 in forum Mori Seiki Mills
    Last Post: 12-10-2017, 02:54 PM
  2. Replies: 5
    Last Post: 06-14-2016, 11:15 PM
  3. Using a Dimensioning Style As a "Default Style"
    By nfrees114 in forum Solidworks
    Last Post: 09-21-2012, 02:37 AM
  4. Autocad Style Sketching vs Constraint Style
    By Beefy in forum Uncategorised CAD Discussion
    Last Post: 08-20-2012, 10:26 PM
