562,489 active members*
3,745 visitors online*
IndustryArena Forum > CAM Software > CamBam > CamBam number format
Results 1 to 10 of 10
    Nov 2012
    1243
    I normally work in millimeters on a Mach3 CNC mill. So my program looks like this:
    Code:
    G0 X123.456 (rapid move to X=123.456mm)
    Problem is, now I need to generate a program for a Syntec machine that works in thousandths of a millimeter. So I need my program to look like this:
    Code:
    G0 X123456 (rapid move to 123456/1000 = 123.456mm)
    I can make CamBam output exactly 3 decimal places after the point by tweaking the post processor:
    Code:
    <NumberFormat>0.000</NumberFormat>
    But how do I get rid of the decimal point, short of doing "Search and replace" in a text editor?
    Jun 2015
    3801
    Re: CamBam number format
    hope attached finds you well
    Nov 2012
    1243
    Quote Originally Posted by deadlykitten View Post
    Thanks Kitten, but Find/Replace is exactly what I was hoping to avoid.
    Jun 2015
    3801
    then how else you wanna fix it in a text editor ? aaaa, you mean to edit the post ... sorry, can't help with that
    but i can create a small program, to fix your file / background work service
    Nov 2012
    1243
    Thanks for the offer Kitten, but that would be overkill. I only had 3 programs to make for the Syntec, so I did it in the text editor.
    Still would be nice to find a solution for the post processor though.
    Jun 2015
    3801
    i no longer deal with posts edit ... regardless of cam, as long as its generates a file, i can take it from there
    all this methods for post edit, different implementations, diff softwares ... is a mini madness, even if you know them all not to mention the duration of learn curves
    so, there is a common part in all of them, if you can see it
    Nov 2012
    1243
    I wrote a Powershell script that converts all numbers for X, Y, Z, A, I, J (but leaves alone F).
    I wonder if there is a way to run the script automatically from the post processor? I think I might have seen something like that in the CamBam documentation...
    Code:
    rem Processes all .nc files in the current directory.
    rem Replaces X123.456 with X123456 for my Syntec controller
    for %%a in (*.nc) do (
    echo %%a
    powershell -Command "(gc %%a) -replace '([X|Y|Z|A|I|J]\-?\d{1,4})(\.)(\d\d\d)', '$1$3' | Out-File -encoding ASCII %%~na-Syntec%%~xa" )
    Jun 2015
    3801
    so it simply scans all *.nc files, and replaces all X***.*** with X***** ? who runs it ? you have to execute it manually ?
    Nov 2012
    1243
    Yes. The results are saved as new files ("-Syntec" is added to the original file name). The original files remain intact.
    For now I run it manually after posting a program. There might be a way to automate it in CamBam, I don't know for sure yet.
    Jun 2015
    3801
    hy citizen ( of dreams ) i automate by creating a service, or having exe hidden startup run, then loop repeat
    having them to fix post files, idea come when someone complained about having to fix the file each time after post
  1. Replies: 0
    Last Post: 12-10-2014, 01:11 AM
  2. MS-DOS format to OSP format
    By bbarber80 in forum Okuma
    Last Post: 04-28-2014, 12:17 PM
  3. Replies: 14
    Last Post: 09-19-2013, 01:30 PM
  4. Bad Number Format error
    By bmurph in forum Mach Software (ArtSoft software)
    Last Post: 01-24-2012, 02:15 AM
  5. CamBam
    By ckjk616 in forum CamBam
    Last Post: 10-28-2010, 11:19 AM
