559,621 active members*
3,610 visitors online*
IndustryArena Forum > CAM Software > CamWorks > Camworks lathe and mill/turn not posting Return to Home on Tool Change G28 code
    Feb 2009
    15
    Does anyone notice that the "Return to Home on Tool Change" checkbox in the turning dialogues doesn't make any difference in the posted codes? For example, if I checked that box I would expect the following code at the end of each turning operation with a subsequent tool change : G28 U0 W0.
    I could hard code this line in the EC Editor, but that's not what I really want... I want it to be posted as and when I checked that box. I have tried all the different retract strategies but no results. Following is what it does:
    Return to Home : Whether OFF on ON
    When next operation is different tool
    Retract to : Preset Position
    Post : Preset Position values
    Retract to : Retract Point
    Post : Retract Point values
    Retract to : Auto / Retract Point Then Preset
    Post : Retract Point values, then to Preset Position Values
    Retract to : None
    Post : Last cut position
    When next operation is same tool
    Retract to : Auto
    Post : Continue from last cut
    Retract to : Retract Point Then Preset
    Retract to : None
    I dug into the machine.src, machine.lib, millturn.lib or lathe.lib, master.atr and scrolled through EVERY SINGLE LINE (took me few days full time) including search words that might reference that checkbox attribute or its argument and still no luck. Does anyone happen to know what checkbox attribute name is?
    On an ending note, I feel like Camworks is slowly fading away. I mean their latest version is 2020 although we're approaching 2023 so... idk.
    Jan 2014
    32
    Quote Originally Posted by newcomer9747 View Post
    I’m running CAMWorks 2022. It was released 12/28/21
  1. Return to tool change pos.
    By jones89 in forum SIEMENS > Sinumerik 802D/840D/810D/828D
    Last Post: 11-22-2021, 10:22 PM
  2. g28 help Looking to get rid of g28 with forced tool change X8
    By nickhyatt24 in forum Post Processors for MC
    Last Post: 10-31-2015, 03:35 AM
  3. Adding G91 G28 Z0 after every tool change?
    By orion_134 in forum Post Processors for MC
    Last Post: 08-14-2013, 10:28 AM
  4. X3 How to send Lathe home with G28
    By mroy0404 in forum Mastercam
    Last Post: 11-04-2010, 08:59 PM
  5. Camworks and Mill/Turn
    By Jay Kyle in forum CamWorks
    Last Post: 10-02-2007, 03:15 AM
