504,500 active members
3,530 visitors online
IndustryArena Forum > CAM Software > EnRoute > Can someone help me ?
Results 1 to 8 of 8
    Dec 2010
    71
    I have 4 rou files I would like to convert to dxf if someone could be so kind to help me I would bee werry grateful.
    I think its Enrouter 4 files if I do remember correct.
    Multicam 300___Enrouter 4 PRO
    CNC 6040 Router Engraver Drilling and Milling Machine___Mack 3
    Sep 2005
    1610
    Re: Can someone help me ?
    You mean EnRoute 4 don't you? Like> https://www.axyz.com/us/enroute/
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router
    Dec 2010
    71
    Yes I think it is that, can you convert them?
    I would really appreciate it.
    It is files for this table we made.
    Butt I forgot to convert them before we sold our machine.
    Attachment 423684
    Sep 2005
    1610
    No I can not, but do you have the gcode files perhaps on a USB drive or some other place?
    I could not open the one file "Svensk_Bondestil_Benk_Gravert_Witches.rou" with Enroute, it might be corrupt. But here are the other 3 exported from Enroute as DXFs.
    Dec 2010
    71
    Quote Originally Posted by Todd Zuercher View Post
    Thank you very much, I owe you one :wave:
    Have a nice day.
    No problem, You're lucky I even saw this post, this is the 1st time I've checked this forum in a very long time.
    I took a closer look at the file I could not open, and it is actually a machine code file (some dialect of G-code). Guessing you may have accidentally over written the Enroute file outputting code to the machine once. Looking at it in Backplot I am guessing it is pretty much the same as the shape in the file "Svensk_Bondestil_Benk_B_400_H_370.rou" but with a little different tool pathing (no Idea if the scale is the same). The v-carving part is using many passes in the g-code file vs 1 pass in the Enroute one.
    Dec 2010
    71
    Thanks again, I looked at the files and the files you converted is the ones I need.
    The last one is most likely with a symbol in the midle.
    I found a photo of it.
ID:	423738 Click image for larger version.
Name:	serendip bord2 018.jpeg
