593,374 active members*
6,639 visitors online*
Results 1 to 11 of 11
    Nov 2007
    79
    cannot create G54 cordinates
    Hi Gents
    I have cnc milling with meldas 64m control,with out APC coder, last week i was working on battery replacement and parameter back up (it was long sad story)
    i didit manually, any way finally i could bring the machine back to life every thing is working fine except when i want to set G54 ordinates when i press soft key (work) I see G54 and the rest of the group the problem starts when i want to input in brackets once i press number five i get immediately an alarm (E 06 NO SPEC) and i couldnt set any value
    so please if any one know's how to sort this problem out it will be really appreciated
    thnx in advance for any help
    rgs
    Re: cannot create G54 cordinates
    Hi dear
    Your might not have entered the option data . In M64 option data is lost when formatted. thats why you are getting e06 no spec alarm.
    Regards
    Hemanth.p
    +91 9962328434
    Nov 2007
    79
    dear sir
    thank you very much for your reply
    please advice for how to get these missing option data, if you have at least similar machine , i contacted the machine builder in Taiwan they reply me with back up parameter but it was for different machine
    that was even with different motor drive so it was useless , i called them again they said that the company was emerged to another bigger company ,
    so if you have any back up parameter please send me ,
    i have attached photo for the machine
    thank you again for your help
    May 2017
    Hello my friend.
    I have the exact same problem. Were you able to find the solution? Can you help me out?
    Please explain the problem
    Please send me the details to my phone
    My number +91 9962328434
    I use whatsapp, FACEBOOK MESSENGER,Skype.
    May 2017
    Quote Originally Posted by hemanth007 View Post
    This is the image I get at the setup registry when I try to insert any data. E06 NO SPEC. All the rest of the machine is working properly. I contacted the machine's manufacturer and they instructed me to use parameter 1060 to format the parameters and re-enter them. I did as they advised but the result is the same.
    Quote Originally Posted by alexopoulos22 View Post
    Option data is specific from machine to machine also it changes from Controller to controller.please mail me the machine details and pictures so i can guide you
    My Mail : [email protected]
    May 2017
    4
    Hello, did anyone resolve this problem? I have the same issue. When I restore from the ALL1 backup I can access the G54 coordinates, if I turn off power and re start then I get the same E06 error.
    Quote Originally Posted by robbas View Post
    Hi robbas
    You can mail me the details of the machine and problem you are facing we can give you the solution
    When battery backup is lost there is a procedure to restore the data
    My mail : [email protected]
    Jul 2015
    10
    Hello everybody,
    I have the same problem. I get the error 'e06 no spec' when I want to enter the coordinates in G54, does anyone have a solution?
    Jun 2021
    16
    did anyone solve this problem?
    Sep 2024
    16
    Quote Originally Posted by MJRx View Post
    yes
  1. cnc moving in negative cordinates
    By unreal123 in forum Machines running Mach Software
    Last Post: 03-01-2015, 03:32 AM
  2. change Fanuc 0-M display cordinates
    By TWM in forum Uncategorised MetalWorking Machines
    Last Post: 11-27-2012, 02:35 AM
  3. No dots in cordinates
    By quasarix in forum Post Processors for MC
    Last Post: 10-30-2010, 07:39 AM
  4. Create pdf from bcc V23
    By RMT41 in forum BobCad-Cam
    Last Post: 03-23-2010, 02:46 AM
  5. Create Arc
    By jcnewbie in forum Mastercam
    Last Post: 01-07-2010, 04:28 AM
