593,377 active members*
6,374 visitors online*
Results 1 to 4 of 4
    Mar 2010
    11
    Cannot delete file memory
    I have Fanuc OMA. Has 32K memory. Control shows it has "0" memory left but it will not let me delete programs in memory - says it doesn't have any files in memory.
    Is there a Parameter setting controlling this? And which one?
    Dec 2008
    3179
    Re: Cannot delete file memory
    Fanuc has a protected area where system files are kept away from the curious operator. The most common is the toolchange macro. These are in the O8000 to O9999 range.
    Memory would be used up & files not be able to be seen, UNTIL you un-protect this range.
    Once unprotected, carefully rename/delete or copy files. And restore the protected status of that area.
    Removing the wrong files can stop your machine from functioning correctly.
    I suggest doing a backup copy of parameters and macros whilst unprotected
    I am unsure of which parameter that controls this protected area.
    Mar 2010
    11
    Quote Originally Posted by Superman View Post
    I have changed a few things in the Parameters over the years. Still gives me the "Shivers".
    Can you give me your version of how to backup the parameter etc. files? I am on a Mac
    Thank you for answering my queries
    Mar 2010
    11
    I returned to machine yesterday. Done the delete with 0 - 9999 exactly same as had done before, this time it cleaned the memory and number of programs
  1. OSP-300 how to delete file
    By mikrej in forum Okuma
    Last Post: 08-24-2020, 10:36 PM
  2. Sinumerick 802c full memory i can't delete files
    By leonardoaa1206 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 10-02-2019, 09:06 PM
  3. Coreldraw - can't delete a path for my plasma file
    By Beefy in forum Waterjet General Topics
    Last Post: 07-24-2011, 04:25 PM
  4. Command file to delete files
    By Karl_T in forum CamSoft Products
    Last Post: 09-07-2008, 12:05 AM
