601,787 active members*
2,734 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Can't copy/paste program file from network folder to cnc internal memory
Results 1 to 5 of 5
    After a lot of trial I set up my fanuc 32i model b as FTP client to access programs from a folder hosted at my FTP server. I can see the files in the remote folder from the cnc machine, but I can't copy paste the files to the internal memory folders. When I hit "paste" in the internal memory folder I get an error "can not copy/move" (see the attached picture). However I can copy files from the USB drive to the internal memory folders, I don't get it why it won't work the same way.
    Re: Can't copy/paste program file from network folder to cnc internal memory
    Quote Originally Posted by sdomingues View Post
    Even though the CNC can see the files, if the FTP user account only has read-only access, the CNC might fail to properly download or move them.
    This is because the “copy” function might involve some temporary write permissions.
    Check your FTP server settings and make sure the user credentials used by the CNC have read and write permissions to the FTP folder.
    Dec 2009
    1024
    When using the FTP transfer from the PC to the internal machine memory, you can not COPY/PASTE as from USB or CF card because the CNC can not hold the data on buffer as is external source that is not present on the mainboard like USB or CF card
    if you want to copy the files from the PC to the machine meory using the machine interface ,you have to use the fucntions that re there and i mean PGET pset and FSET
    if you want a easier way ,go by the Fanuc transfer tool software for 20 euro that is a simple software created by Fanuc and is a DRAG and DROP system for copying files form the CNC to PC and viceversa with a blink of an eye
    Quote Originally Posted by zavateandu View Post
    In my case I select the file, click the soft keys "F input" followed by "f get" and then "exec" but I get the error "cannot use I/O device". Chatgpt says this happens because I need to change the destination device, does this make any sense?
    It's done, some alarm on the machine was preventing the "F INPUT" from the input device, we cleared the alarms and now it works.
  1. Copy/paste editing of a program
    By MRPM in forum Mori Seiki lathes
    Last Post: 03-16-2017, 05:05 AM
  2. Replies: 18
    Last Post: 02-16-2016, 11:53 AM
  3. i can`t copy a program fom USB memory to CNC
    By alain aleman in forum Fanuc
    Last Post: 06-10-2015, 11:45 PM
  4. Copy and Paste
    By MetalShavings in forum Solidworks
    Last Post: 11-11-2011, 11:20 PM
  5. copy and paste
    By Claude Boudreau in forum BobCad-Cam
    Last Post: 11-25-2009, 10:55 PM
